Previous in Forum: Lighting Transformer   Next in Forum: Load Calculation & Load Balanceing
Differential Protection in Delta Connection
01/25/2011 1:27 AM
Hi,
It is said that for unbalanced loads ,Delta Connected power Transformers are majory employed.
1. How then is Differential and Earth fault Protection achieved,seeing that this connection allows unbalanced currents.?
2.What acts as a return path seeing there is no neutral?
Best Regards.
Re: Differential Protection in Delta Connection
01/25/2011 1:53 AM
Why dont you read the topic in online ?internet is an information resource.
Engineering Fields - Electrical Engineering - New Member India - Member - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Safety - ESD - New Member Engineering Fields - Power Engineering - New Member
01/25/2011 7:14 AM
capacitance between the line and the source act as path for the earthing................In ungrounded system the fault detection & clearing is not possible. Only alarm can be raised for the ground fault in ungrounded system, which is further difficult to locate the fault
Correct Me If Iam Wrong, Suggestions/Recommendations needs to be verified before implementation
Register to Reply 2 comments
