Previous in Forum: Motor for ID Fan Application   Next in Forum: Differential Protection in Delta Connection
Lighting Transformer
01/25/2011 12:16 AM
What is the need of installing lighting transformer? How it reduces fault level in the lighting circuits???
Re: Lighting Transformer
01/25/2011 3:34 AM
Guest; what?
01/25/2011 5:22 AM
It doesn't do that. It reduces the voltage of the lighting circuit to a level that is compatible with the instralled lighting elements' input requirements.
Engineering Fields - Electrical Engineering - New Member India - Member - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Safety - ESD - New Member Engineering Fields - Power Engineering - New Member
01/25/2011 7:18 AM
lighting transformer impedance, will reduce the short circuit fault current.....................to the level of 10kA which is then compatible with the MCB and other components which are used generally in the lighting system
Correct Me If Iam Wrong, Suggestions/Recommendations needs to be verified before implementation
Anonymous Poster (1); PWSlack (1); sms149 (1)
