Previous in Forum: How to Perform Megger Test   Next in Forum: What is a Photohelic Differential Pressure Switch
Problems in Switchyard Charging
01/27/2011 11:31 PM
Dear all,
I am interested in knowing what are the emergencies conditions/ problems will be arising at the time of charging/commissioning of a 400KV switchyard(one and half circuit breaker scheme).
Re: problems in switchyard charging
01/28/2011 12:36 AM
This is definately not my field, but congratulations to you for recognising the need to ask for advice and being prepared to do so.
My thoughts are following
  • You are dealing with dangerous voltages. Consult with the designers, manufacturers and also with those who have commissioned similar instalations in your region.
  • Make sure everything is "dry". (Heard of a high voltage switchroom where condensation on bricks allowed tracking of the arc with disasterous ourcome.) The equipment has not been energised for some time and so there could be vapour/water in the most unlikely places, like inside transformer coils.
  • Make sure that everyone involved is trained/experienced in HV work.
  • Choose the right weather. (Meaning don't try this when there is a thunderstorm anywhere along the transmission line.)
Be careful!
01/28/2011 2:12 AM
thanks but what i need is to know different case studies that happened at commissionining of such a switchyard.
01/28/2011 5:54 AM
Then read the commissioning report for that particular switchyard. It cannot be seen from here!
Good Answers: 181
Re: Problems in Switchyard Charging
01/28/2011 11:19 AM
I think gentlemen we have another Meare in our midst, building a power station in his dreams. Have a look through previous posts.
At least this time it's coal fired and not a "Mega large high head hydro power plant".
Register to Reply 4 comments
Just an Engineer (1); PWSlack (1); raj38 (1); TonyS (1)
