Previous in Forum: What is a Photohelic Differential Pressure Switch   Next in Forum: Leg Ground Fault
Phase to Ground Fault
01/28/2011 2:12 AM
Good morning,
In three phase, three wire ungorunded or resistance grounding sytem,
During phase to ground fault; voltage level of faulty phase is zero,
but voltage-to-ground of the other phases rises by 73 percent.
However phase to phase voltage remains the same and only phase to ground voltage
in two healthy phases increases.
What is the reason of this in technicaly?
What is the main advatages and disadvantages of using 11 kV or 22 kV instead of 33 kV according to the phase to ground fault.
Best Regards,
Musa UÇAN
Re: Phase to ground fault
01/28/2011 3:16 AM
There is an article on earthing in Wikipedia. Look at IT systems there and all will become clear.
Reply to Forum Thread
