Hello all and Thanks in advance for working on my problem. Thank You to CR4 also, for allowing anonymous posts.
Project Problem:
Input (vertical) Shaft 30-33 rpm (est.)
Needed Output 3600+ rpm
Restrictions:
The largest gear diameter would be limited to 20".
I hope this is enough info. I understand basic ratios, but need help the farther up/across the stack I go. I need to find the most efficient way of getting a 1 to 1000+ Ratio. I understand thier may be varying opionions, and welcome all who have the time.
I don't have exact numbers for lack of a working fullsize prototype, I just want to get an idea of what kind of animal I would be dealing with.
Thanks again
Task
