Previous in Forum: Crushing Stress   Next in Forum: Delta T
Rail Track Tolerance
02/03/2011 1:19 AM
Dear all, Am new to the projects am working in yard equipments for raw material handling system it has rail fixing length for 650mtrs so please suggest me track tolerance my rail head width is 72mm and wheel collar width is 100mm double collar *what is level difference between the two lines which i can maintain *What is the maximum track curvature tolerable From ---- MOHAMMED AEJAZ. K
Re: Rail Track Tolerance
02/03/2011 7:22 PM
What track gauge (it is of crucial importance to the matter!)?
For Stephenson's gauge, a nominal 4ft 81/2in between running edges, the tolerances stated in "British Railway Track Bullhead Supplement" 1991 (published by the Permanent Way Institution) are as follows:
Where London Transport Stock only operates:
  • Straight track 4ft 83/8in.
  • Unchecked curves 4ft 81/2in.
  • Checked curves 4ft 85/8in with 2in check flangeway
  • Switches and crossings 4ft 81/2in with 13/4in flangeway.
Anecdotally, London Transport pulled the gauge down to 4ft 81/4in on the departure side of stations so as to stop the power bogies thrashing about under hard acceleration.
Where surface stock also operates:
  • 10 to 7 chains radius 4ft 85/8in with 2in check flangeway.
  • 7 to 51/2 chains radius 4ft 87/8in with 21/4in check flangeway.
  • Under 51/2 chains radius 4ft 91/8in with 21/2in check flangeway.
  • Switches & Crossings 7 chains radius and over 4ft 81/2in with 13/4in flangeway.
  • Switches & crossings under 7 chains radius 4ft 83/4in with 2in flangeway.
Where Stephenson gauge track is curved, the equilibrium cant is given by the equation:
H = 0.06(V2/R)
where H is the cant in inches, V is the line speed in mph, and R is the radius in chains. However, it is common to put on 2/3 of the equilibrium cant so as to reduce the mutual wear at the wheel/rail interface.
Twist across the track should usually be less than 1 in 300, and is immediately actionable if more than 1 in 150. The difference in rail head height for adjoining fished rails should not exceed 1/8in at 50mph.
The above covers UK practice up to about 1956 and is adopted by many of the heritage lines across the country. The UK's current National Rail standards are similar, though metricated, and do not cover London Transport lines, non-Stephenson gauge lines, light rail, nor anything in Northern Ireland, where CIE standards predominate. However, the local track gauge and standards might be different from those above.
In a yard situation, the track is better laid flat rather than worry about cant, as speeds are usually low, and rail wear and passenger comfort is hardly an issue.
For more guidance on first principles, obtain a copy of Kempe's Engineers' Yearbook, a more modern edition, and check out the chapter on track construction. Though based on UK practice, the principles are applicable to rail systems across the globe. India also has many publications on the same topic, most of which tackle the broader gauge found in some places in some detail.
02/04/2011 7:15 AM
Track center to center distance is 6mtrs and another 7mtrs
02/04/2011 5:17 PM
Irrelevant.
Register to Reply 3 comments
You might be interested in: Rail Services, Lockbolts, Shaft Collars
