Previous in Forum: Rail Track Tolerance   Next in Forum: HVAC Design
Delta T
02/03/2011 2:25 AM
We have a pollution system.There are heat exchager and bag filters and by knowing the temperature of heat exchager inlet/outlet and bag filter inlet/outlet how can I calculate the delta T. Before that please tell me what is Delta T
Re: Delta T
02/03/2011 3:01 AM
Delta-T is the change in temperature
Re: Delta T
02/03/2011 1:21 PM
You may be looking for LMTD (logarithmic mean temperature difference) instead of ΔT (which means temperature change). There are various ways to express this; probably there is a good Wikipedia article on it.
Re: Delta T
02/07/2011 11:02 PM
Give a better explanation of your system so we know what you want.
Temperature rise across a centrifugal fan at sea level is about 1/2 degree F per inch of water static pressure.
Does the heat exchanger preheat/precool makeup air? What does it do?
Register to Reply 3 comments
