CT ration is 300/5A.
when u r connecting this CT to Energy meter for measurement purpose, u wil need to calibrate the CT ratio in meter, then only it can show u right readings.
in meter, set the CT ratio, it wil auto-calibrate with current from CT
the way ur question posted "three face energy meter" shows that ur not an electrical engineer to work with energy meter. so stay off from electrical systems bcoz it s very danger to equipments as well as you. sorry if am rude..
You don't understand anything until you learn it more than one way.
