Previous in Forum: Help Identify the Steam Trap   Next in Forum: Anchor Bolt Design
Cooling Strategies For Cryogenic Machining From Materials Viewpoint
02/04/2011 10:12 PM
I wish to read the Whitepaper titled Cooling strategies for cryogenic machining from a materials viewpoint
http://adsabs.harvard.edu/abs/1992JMEP....1..669Z
I have been reading about the concept of Cryogenic Machining for some days now & almost all of the reading material I have collected have referred to this whitepaper.
However, I'm unable to find a source that has made this paper accessible to read for free.
Me being a student with no source of income, I'm unable to pay to read this paper & libraries I have access to do not have this paper.
I would be very grateful if one of you provide me with this paper to read, either by sending me a copy over the e-mail or allowing me access for a limited period of time to some site that hosts this paper.
If you need my e-mail id to provide me the paper please let me know - will post it here ASAP
Thank you
Re: Cooling strategies for cryogenic machining from materials viewpoint
02/04/2011 10:37 PM
Well,
It just goes to show you. There's no such thing as a free "Cooling strategies for cryogenic machining from a materials viewpoint".
02/05/2011 1:46 AM
No, don't post an e-mail address. CR4 Admin will remove it. Refer to CR4 FAQ lower right.
Good Answers: 183
02/05/2011 6:25 AM
"Cryogenic machining - Patent 5901623" Look at this patent the author is also the second on the author list of the paper you try to find. Most probably you will find information about the research paper in it.
Re: Cooling Strategies For Cryogenic Machining From Materials Viewpoint
02/05/2011 11:53 PM
As you are a student you can use your university library facility to download this paper or you can contact any of your professors to get it download
Good Answers: 109
02/06/2011 4:32 PM
These studies of cold machining were done in the late 80ies and early 90ties to overcome the high wear of diamond tools in steel and other metals that may react with diamond to carbides.
In total this approach was not a success as diamond turning is used in high precision applications and this is contradicted by cooling as thermal deformation will damage the result.
So nowadays titanium is machined with natural diamond despite affinity to carbon. Do not turn with high speed and use an ordinary coolant. (Beware the possibility of igniting titanium and let it burn under water!)
And iron-alloys are turned with sintered CBN (cubic boron nitride) that does not have this affinity to carbon. Same for grinding.
There was another approach that had more success (done at NIST) that used hydrocarbon gas as coolant. Also cooling with nitrogen that expands from near 8 bar pressure through a Laval-nozzle had some remarkable results.
All these approaches missed the intended goal - I suspect because cooling was done with constant cooling capacity delivered to tool and workpiece whereas a constant temperature should be achieved at the tool and workpiece together with the smallest possible temperature rise.
This approach would need two independent cold gas (nitrogen) jets and two infrared temperature measurement pyrometers with readout and proportional valves for servo control of the gas flow rate.
RHABE
Popular Science - Weaponology - Chronic intel collector
02/11/2011 8:30 AM
Lockheed Martin appears to have renewed its interest in cryogenic machining
Given a contract to develop an in-tool method of delivering the coolant while machining the workpiece
Lockheed Martin F-35 Leads To New Titanium Machining Process
[quote]
A groundbreaking cryogenic titanium machining process, planned for use in the production of Lockheed Martin's [NYSE: LMT] F-35 Lightning II stealth fighter, will make its public debut at the International Manufacturing Technology Show (IMTS) 2010, Sept. 13-18 in Chicago
[/quote]
Get busy living.... Or get busy dying - The Shawshank Redemption
Good Answers: 109
02/11/2011 9:11 AM
That seems to be great, thank you, may be really important to other "impossible" tasks.
Until now the cooling methods were either too low and insufficient (gas cooling) or
too much and not at the right place.
RHABE
lyn (1); mrswamy (1); nick name (1); PWSlack (1); RHABE (2); slugger (1)
