Previous in Forum: Can CBCT be Used in Restricted Earth Fault?   Next in Forum: Is UL Necessary for RFID Product in USA?
110V DC System - Voltage Question
02/07/2011 11:41 AM
Hi,
110 V d.c system ,what would be the voltage of -ve bus to earth?
Good Answers: 181
Re: 110V DC System - Voltage Question
02/07/2011 12:10 PM
Depends on where the DC system is earthed. Need more information!
02/07/2011 12:45 PM
It will be 0V if the negative is earthed, -110V if the positive is earthed, and if neither is earthed it will be whatever a high impedence digital voltmeter can make of it.... <sigh>.
02/07/2011 1:57 PM
Good evening guys,
Very correct statement PWSlack on the first two cases, i would re-phrase the third case to 'whatever voltage can be created across the insulation leakages (resistance paths) of +ve and -ve poles to ground, including the input impedance of the measuring device in the calculation.
02/08/2011 8:55 AM
hello pwslack, can you kindly explain me how it happens???
keep your hands on a stove for one minute, u feel like a hour.. sit and chat with a pretty girl for a hour, u feel like a minute...That is 'RELATIVITY"/
02/07/2011 5:14 PM
it is dependant to which we will attach the -ve terminal of the AVO ....in case we attached it to the earth we will get +110 whilst a 0 V in case it attached to the ground of the DC system.....However, it doesnt matter which value the -ve terminal would be as we connect the DC system voltage properly to its relevant loads as they isolated completely from the AC system.
Reply Score 1 for Off Topic
02/12/2011 11:56 AM
if you earth the -ve or +ve to earth through multimeter it will decreased the value due to capacitor discharge. I think no value will be shown. or nothing happens due to short the -ve bus to earth.
Anonymous Poster (1); omar_beyaty (1); PWSlack (1); TonyS (1); xformdesign (1); yannissou (1)
