Previous in Forum: Earthing as Neutral   Next in Forum: I.D Fan Problem
AC Motor Start Problem
02/08/2011 3:12 PM
I have 1HP AC Capacitor start motor,when i am switching on motor, it starts after few secs what may be the reason & please give solution also.
Re: AC motor start problem
02/08/2011 3:30 PM
It's busted.
It sounds like your starter circuitry is ineffective. Examine all of the parts of your starter circuit. It may even be that you have too large of a mechanical load to start too. The mechanical failure could be anything from a failed bearing to a misalignment.
02/08/2011 3:51 PM
Although there might be mechanical binding etc., my first suspicion would be a bad starting capacitor, followed by some control step not working.
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
02/08/2011 5:00 PM
It's knackered. I've got plenty of replacements in Dodgy Dave's lock-up on Canvey Island, though. Just send cash. <Splutter, wheeze>
Essex jobs for Essex yobs! <Burp>.
Good Answers: 16
Re: AC Motor Start Problem
02/08/2011 6:57 PM
The answer is more than likely in your posted question. Start by qualifying the capacitor, then the switching mechanism.
02/08/2011 8:10 PM
I am not clear,should i replace capacitors(it is having two) with new one(same capacity) or should i go for higher capacity capacitors
02/08/2011 8:38 PM
The capacitance value of the capacitors delay the current a precise amount of time compared to the primary current so that a proper higher torque is available during low speed start up. So do not vary the capacitance value at all. You can go for a higher voltage rated capacitors if they are available in a suitable package size but do not change the capacitance value significantly.
Anonymous Poster (1); redfred (2); Stinky Pete (1); Tim in Mexico (1); Tornado (1)
