hello!
does anybody here has an experience about belt scale.
The issue here is the total accumulated material mass being measured in belt scale is much higher than than the coal delivery invoice. we are in a coal fired power plant and we received fuel coal delivered from indonesia. usually the delivered coal was stated in the invoice 5,500 tons and when we unloaded, the measured coal in the belt scale was 6,800 tons which more that a thousand tons diff.
we recalibrated the belt scale and we came up an accuracy of 0.12% in which it satisfies the system design accuracy of +/- 0.5%.
In your analysis, what might be the possible cause of this discrepancy? considering that the BS is propely calibrated as far as accuracy is concern.
The coal barge had sailing from indonesia to Philippines and heavy rain might be encountered along its sailing.. rain water or sea water might store in the coal pile aT the barge and can be also taken during coal transfer frOm the barge to coal yard..can this be the cause why every time we unload the coal its accumulated tons is much higher than the invoice and can reached even a thousand diff?
