Previous in Forum: Calculating Demand Factors?   Next in Forum: All About Electrical PMs
9 comments
Furnace Energy Consumption
02/10/2011 6:34 AM
We have a 10 mva furnace transformer and 1000 kva aux. transformer. Whenever the furnace is switched off the auxiliary energy consumption is found more than that in on condition. Why is it happening so?
Re: energy consumption
02/10/2011 6:50 AM
When the furnace shuts down, does some alternate energy source kick in on the auxiliary transformer?
India - Member - New Member
Good Answers: 164
02/10/2011 7:22 AM
Er... you do mean mega-volt-amperes ? This is generally written as MVA, as opposed to millivoltamperes, which is written as mVA ... just to be sure.
02/12/2011 3:36 AM
Its MVA sir
Good Answers: 164
02/12/2011 3:51 AM
i hope you were not offended by my editorial correction, just pre-empting some other caustic poster
Btw, what kind of a furnace? Induction by any chance ? Are there lots of capacitors on the system ?
02/12/2011 9:55 AM
It is a submerged arc furnace of 10 MVA .Unfotunately there is no capacitor bank connected either in furnace transformer or in the system.The plant is in kuwait.
Good Answers: 164
02/12/2011 10:13 AM
Anyway, you have clearly mentioned kWH, so any capacitors wouldn't have any effect on that.
Sorry, not my field. Anyhow, given that it is Kuwait, the supplier must be falling over himself to help ? Any negative feedback, and he is a goner.....right?
Good Answers: 181
Re: Furnace Energy Consumption
02/10/2011 3:01 PM
OK I've only worked on furnaces up to 3MW. The secondary control was off a separate 11KV fed transformer.
Take the control off a separate supply.
Good Answers: 116
02/11/2011 1:34 PM
You write "auxiliary energy consumption".....
  1. Do you mean the reading of a Watt-hour meter (kW-h)?? - that is energy consumption.
  2. If the furnace is off for longer time than it is on, then a smaller load for the longer time could build up a greater change in kWh recorded.
  3. How big an auxiliary energy consumption are you seeing? Furnace running and furnace stopped values please.
02/12/2011 3:45 AM
yes sir I mean KWh ie energy consumption.The auxiliary energy consumption is greater (more or less 2000 KWh ) when the furnace is off than that in on.
Register to Reply 9 comments
67model (1); gkkumar (3); kvsridhar (3); TonyS (1); Tornado (1)
