Previous in Forum: Compliance Certificate   Next in Forum: Deltrol Fluid Products
Sensor for Lowara Borehole Pump
02/11/2011 9:03 AM
Hi
We have dismounted bore hole submersible pump which have three sensors, two of the sensor are at the bottom, hope they sense upper and lower level of the water. I am not sure about the third sensor, could anyone who have similar borehole help to to know the function of the third sensor.
Regards
Dickson.M
Re: SENSOR FOR LOWARA BOREHOLE PUMP
02/11/2011 9:54 AM
Where is the third sensor in relation to the other two?
02/11/2011 11:27 AM
tHE THIRD SENSOR IS AT THE TOP OF THE BORE HOLE
02/11/2011 11:50 AM
All the submersible pumps I install with the three 'sensors' are to ensure the pump does not try to pump water when there is insufficient water to keep the pump cool! The 'sensors' are:-
Bottom-common, Just above the intake of the pump (Above the motor and the filter)
middle-just above the common about 20cm or higher if the pump is high capacity. This is the motor shut off.
Top-motor restart
The Top 'sensor' needs careful consideration. Too low and you risk the motor starting too soon after it has stopped due to the water level raising , which may start the motor while the water is still coming back down the tube causing nasty water hammer resulting in a broken motor drive shaft! This 'Sensor is best left up near the natural water level or a few meters under it to allow for a low water table!
These three sensors are just like contacts on a switch where the water acts as the bridge between them! They all go to the pump control box to do their magic!
Register to Reply 3 comments
dmtonyole (1); Mr. Truman Brain (1); PWSlack (1)
