Previous in Forum: Ss Welding With Out Using Purging Gas In Gtaw Process   Next in Forum: Pipe Cost Comparison
9 comments
Enquiry
02/12/2011 3:24 AM
i have 4 water closet unit and i want to know the pipe size that im going to use for my main line dischraging to the manhole?
Re: enquiry
02/12/2011 3:34 AM
Comply with local building regulations.
Good Answers: 11
Re: enquiry
02/12/2011 5:36 AM
a 100mm dia pipe will do, just make sure the slope is maintained with in the range of 5% to 13% and fittings (45 & 90 deg) bends are installed in consistent with the plumbing code.
Above answer, is best preferable consult local building regulation.
Good Answers: 145
Re: Enquiry
02/12/2011 7:29 AM
90mm swv
Re: Enquiry
02/12/2011 9:16 AM
Could somebody please translate. I was born in Arkansas and led a sheltered life.
Re: Enquiry
02/12/2011 10:54 AM
It appears to me that this member is trying to size a discharge pipe for a facility having 4 toilets. Usually a 4 inch discharge line is used in houses with more than 3 toilets. The grade is 2 percent to the septic tank and the laterals are usually laid at 1% slope. The grade is kept so small to prevent the liquid from outrunning the solids..
Re: Enquiry
02/12/2011 11:05 AM
GA and welcome to cr4
klearzen
Re: Enquiry
02/12/2011 11:31 AM
Welcome, and thanks.
That part about discharging into the manhole bothered me. But then, I take everything literally.
Re: Enquiry
02/13/2011 1:01 PM
Unpleasant for the sewer workers.
Re: Enquiry
02/13/2011 11:12 PM
Good answer except the questioner is running to a manhole which presumes a community sewer system. In which case the lateral is the line from the lot to the main and is usually kept at 2% also, Then the sewer mainlines will run at 1% due to their increased size and thus need to maintain flow depth for consolidation of fluids and solids. Just make sure it runs downhill and don't chew your fingernails.
Register to Reply 9 comments
Anonymous Poster (1); damengineer (1); klearzen (1); lyn (2); Noudge79 (1); PWSlack (1); Sourdough (1); Tobugrynbak (1)
