Previous in Forum: Reasons for Back Fire in afbc Boiler   Next in Forum: HVAC
Drill Bit
02/13/2011 9:08 AM
DEAR SIR,
I HAVE ONE SS PLATE MATERIAL IS SA240-304L I WANT TO MAKE HOLE IN THIS PLATE SO WHICH KIND OF DRILL BIT WE CAN USE.
Re: DRILL BIT
02/13/2011 9:29 AM
First a lesson in net etiquette, typing in only capital letters is considered to be SHOUTING and is very rude.
Now I would expect that almost any set of carbide tipped drills will work fine on nearly any practical hole diameter to a reasonable depth. You may be able to get away with High Speed Steel drills if you go slowly and remove only a small amount of material on each bit by starting with a small diameter hole and stepping up a little each time. For obvious reasons do not use any of the variety of wood bit drills.
You provide so little information and ask such a basic question that I wonder if you should be machining anything.
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: Drill Bit
02/13/2011 1:20 PM
Anything you bleedin' like so long as you KEEP THE NOISE DOWN! <Cough, splutter>
Essex jobs for Essex yobs! <Burp>.
Re: Drill Bit
02/13/2011 9:21 PM
Shallow cuts are undesirable in machining SS (at least some types of it), because it work-hardens. Use a relatively slow rpm, a relatively fast feed rate, and lubrication. Cobalt bits are commonly used, but other types will also work (though they might not last as long.)
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Re: Drill Bit
02/18/2011 11:29 AM
Stainless steel is notoriously tough on drill bits, compared to drilling trhu carbon steel. Make sure you use small increments in working toward the size that you need. And I assume you will be using a drill press, not a hand-held drill. You can break a wrist with a hand-held.
Out of Box Experience (1); redfred (1); Stinky Pete (1); Tornado (1)
You might be interested in: Guide Bushings and Drill Bushings, Drill Bits, Drills
