Previous in Forum: Procedure for Instrument Impulse line   Next in Forum: Cause and Effect Diagram
Level Indicators for Carboxylic Acid Dehydration Column
02/14/2011 2:49 AM
Dear Freined,
We have an azeotropic distillation colum where carboxylic acid is dehydrated to produce anhydrise.The problem with us is that level indicator of the colum becomes chocked most often and we have to rod it most often )daily basis and some time 3 times a day).
LI Characteristics are as below:
Medium:O-Xylene/CARBOXYLIC ACID solution (50 % MA impure)
Medium state:Liquid
Supended matter;Yes
Corrosive:Yes (highly)
Temperature:168 deg C
Operating Pressur:1.1 bar abs
Crystallization point:52 deg C
Density:1095 Kg/m^3
Dynamic viscosity:0.25 mPa.s
Allowable guage poressue:0.5 bar max
Temperature allowable max:200 deg C
Body material :316L
IP Enclosure to DIN 40050 :IP 65
Connection terminals el design:2.5 mm
ambient temp:45 deg C.
Probe type of construction:Rod fully insulated
Output signal analog :4-20 mA
Aux energy voltage : U 24V d.c
type:capacitive
Please verify and suggest right instrument for level transmission.
Pathfinder Tags: dhc
Re: LEVEL INDICATORS FOR CARBOXYLIC ACID DEHYDRATION COLUMN
02/14/2011 4:48 AM
Ultrasonic or radar level transmitter.
02/14/2011 5:40 AM
Please i need professional level reply.Do compare both instruments with reference to operation,maintenance and cost.Additinally some references are quite important in this concern.Appropriate reply will lead to a perfect solution.I need some vendors detail too
Best Regards,
Akram
02/14/2011 6:17 AM
follow this link
http://us.magnetrol.com/industries.aspx?industry=6
click on Distillation Column
you can get further details by vendor.
Regards,
Amey D
02/14/2011 8:45 AM
Can I shine your shoes, walk your dog, or buy you lunch while I'm preparing this engineering analysis for you?
02/14/2011 10:34 AM
This is why you hire knowlegable engineers... for competent evaluations... having vendors evaluate this will only slant it to thier hardware... this advice is free, but free engineering evaluation is only as good as what you pay for and can cost your dearly in the long run...
02/14/2011 1:00 PM
Would you like fries with that? Ketchup?
Register to Reply 6 comments
Anonymous Poster (3); M.Akram (1); ral412 (1); Tornado (1)
You might be interested in: Lead Acid Batteries, IP Cores, Level Sensors
