Previous in Forum: Sizing of Industrial Furnace   Next in Forum: Can We Model Something Like a Thread / Wire Rope (Flexible) in Unigraphics?
Piping Wall Thickness Calculation (Cryogenic Application)
02/14/2011 6:35 AM
I want to calculate wall thickness with following details:
Pipe size=16"
Design Temp= -105deg C = -157 F
Design Pressure= P = 3.5 kg/cm2 g = 49.78 psi
pipe material= A358 TP 304
by using formula:
t = PD / 2(SEW + Py).....................from ASME B31.3
(where t= minimum wall thickness required, P= internal design gage pressure, D= outside diameter of pipe
S= stress value for material from Table A-1,
E= quality factor from Table A-1A or A-1B,
W= weld joint strength reduction factor per para.302.3.5(e),
Y= coefficient from Table 304.1.1)
calue of S, for given temperature, considerng as 20000 psi
thickness comes out to be 0.4 mm, which is obviously not acceptable asit will not even sustain the SELF WEIGHT.
So my dilemma is:
1. Am I using right formula for thickness calculation?
2. Is there any modified formula for Cryogenic piping?
Help me on this exercise to find out the thickness with proper justifications.
This discussion was "closed" on 02/14/2011 1:40 PM. No new comments are allowed.
Message from admins:
Duplicate Post - see http://cr4.globalspec.com/thread/65856
Good Answers: 137
Re: Piping Wall Thickness Calculation (Cryogenic Application)
02/14/2011 11:25 AM
Why don't you read the responses to your previous post on this subject? All the information you need is there. And then try to put a bit of thought into it. Most of us are glad to help, but we don't like being asked to do all the work for somebody who won't make any effort.
Codey
02/14/2011 1:19 PM
There are now three posts on this topic....
Register to Reply 2 comments
You might be interested in: Cryogenic Equipment, Cryogenic Pumps, Thickness Gages
