Previous in Forum: Cause and Effect Diagram   Next in Forum: Manifold
Compensating Cable Substitution
02/14/2011 12:42 PM
Dear all as we know we r using compensating cable for carrying mV of thermocouple . I want to know what is the resistance of that cable per unit length. Can we use copper cable in place of that, as the resistance of Co cable is less than that. Is there any other parameter coming in to place. please clarify me. JITENDRA
"MAKE CHANGES BEFORE THEY ARE FORCED UPON YOU." "PROBLEMS ARE SIMPLY CHALLENGES WAITING FOR SOLUTIONS TO MEET THEM"
Pathfinder Tags: compensating cable
Re: compensating cable substitution
02/14/2011 12:58 PM
Measure it?
Good Answers: 19
Re: Compensating Cable Substitution
02/14/2011 6:15 PM
1) The resistance of thermocouple extension wire is much higher than the corresponding gauge copper wire.  Tables showing T/C wire resistances can be found using our friend, Google. 2)  It is absolutely forbidden to substitute copper cable for thermocouple extension wire.  This is an axiom of physics. 3). Many analog inputs have a limit to how much wire resistance the input can tolerate. 4). The need for long run copper cabling for thermocouple measurement was addressed some 50 years ago with the use of '2 wire loop powered temperature transmitters'.   The thermocouple connects locally to the transmitter 'out at the process' and the transmitter sends a 4-20mA current signal back to the receiver (DCS, PLC, controller, recorder, indicator) over copper wire.   The technique is suitable for very long distances.    Our friend Google will gladly amplify on this subject for you. 5). The chemical symbol for copper is Cu, not Co.
Good Answers: 19
02/14/2011 6:24 PM
The iPhone is hopelessly out of its league trying to edit posts. The gargantuan paragraph above displayed perfectly as separate, itemized sections (paragraphs), but the layout changed radically when submitted. The iPhone cannot navigate in the edit window. Technology is only great when it works.
Good Answers: 116
02/16/2011 7:40 AM
I had the same problem with Opera, Bud, I have to use Firefox (Internet Exploder also works) when I make posts, else paragraphs get merged - also the toolbar for inserting images, bullets/numbers, special characters e.g. β does not appear and you cannot insert.
Good Answers: 116
02/15/2011 2:44 PM
  1. A thermocouple cable is used to connect a thermocouple if you want accuracy.
  2. That means for Chromel Alumel [NiCr-NiAl] thermocouple you use NiCr and NiAl leads of the same alloy as the thermocouple.
  3. Compensating cable uses cheaper materials which around ambient temperatures have the same e.m.f. versus temperature as the thermocouple alloys. Much away from normal room temperatures you get errors.
  4. If you use copper cable you will get a temperature error equal to the difference of temperature between the terminals at which you connect to the thermocouple leads and that of the terminals on the measuring instrument. This error is usually too much to accept, especially since it is variable and difficult to know.
Look at website www.tc.co.uk and get the free guide. Read it, learn it and think about it.
Website www.omega.co.uk also has useful free manuals, some down-loadable.
67model (2); Bud (2); PWSlack (1)
