Previous in Forum: Check Valve on De-Coupler Line of Chilled Water System   Next in Forum: Variable Displacement Pump
Maximum Wall Thickness for 14 inch SA335 Gr. P22
02/14/2011 1:58 PM
I want to know that what can be maximum wall thickness for 14 inch SA335 Gr. P22 Pipe as as per pipe schedule chart it is showing max. 35 mm thick were as in our superheater piping we are using 53 mm thick
Re: maximum wall thickness for 14 inch SA335 Gr. P22
02/14/2011 2:25 PM
Then would it be tube rather than pipe?
Re: Maximum Wall Thickness for 14 inch SA335 Gr. P22
02/15/2011 7:17 AM
This pipe is fabricated by ASME B36.10, then the maximum tickness is 63.50 mm. See table 1 form ASME B365.10M.
02/16/2011 1:22 AM
hi peter,
ACCORDING TO B36.10 ED2004,
THE MAXIMUM THICKNESS FOR THE LOW ALLOY STEEL P335 Gr P22 = 35.71 mm
FOR ANY QUESTION DONT HESITATE TO CONTACT
QA/QC ENG: AMR SOLIMAN
EMAIL: met_3mr84@yahoo.com
Register to Reply 3 comments
