Previous in Forum: Can We Model Something Like a Thread / Wire Rope (Flexible) in Unigraphics?   Next in Forum: Maximum Wall Thickness for 14 inch SA335 Gr. P22
Check Valve on De-Coupler Line of Chilled Water System
02/14/2011 1:16 PM
Do i need a check valve on de-coupler line?
Thanks
Re: check valve on de-coupler line of chilled water system
02/14/2011 1:18 PM
Only if it is intended to prevent reverse flow in the line.
Re: Check Valve on De-Coupler Line of Chilled Water System
02/16/2011 3:50 PM
No just need to maintain the critical distance between branches on the primary and secondary systems typically 24" or 3 x the pipe diameter for large bore De-couplers.
Register to Reply 2 comments
