Previous in Forum: Variable Displacement Pump   Next in Forum: Fireproofing painting
Hot Oil Bath Pump Design
02/14/2011 6:10 PM
I'm designing a heating/circulation system for a constant temperature mineral oil bath. I plan on using a circulation type heater with a pump; however the cost is rather astronomical for a mag-drive pump (~$2K for the one I got quoted).
Here are my system details:
-atmospheric pressure
-total mineral oil bath capacity (Multitherm OG-1): ~14 gallons
-operating temperature: 450F
-desired flow rate: ~10-20 gpm
Originally I was going to go with an independent pump, but the mag-drive pump I got quoted was too expensive. Is there a way I can simply circulate the oil using an axial flow impeller and a motor inside of a U-shaped pipe attachment on the bath? Something like a vertical turbine pump running in reverse. I could even place a screw plug heater on the horizontal part of the U (going back into the bath) to create a combo pump-circulation heater.
Re: Hot Oil Bath Pump Design
02/14/2011 6:31 PM
How about an over-the-edge propeller-type pail mixer, with the motor above and away from the oil heat?
Good Answers: 21
02/16/2011 1:53 PM
I just put in a year and a half or so ago a hot oil boiler system using a standard centrifugal pump designed for the application 450 deg F. There are several manufactures of these pumps out there in the market place and they are fairly reasonable to purchase. < $1,600.00 US.
Good Answers: 58
02/16/2011 9:28 PM
I don't know why a standard heating circulating pump won't do your job. I remember a B&G brand name that was very reliable. An external system would give you a chance to add a filter, too.
mike k
fixitorelse (1); mike k (1); Tornado (1)
