Previous in Forum: A very legible video, any engineer can appreciate   Next in Forum: Nautical Science
8 comments
Hot wire for small robots
04/03/2007 8:21 AM
Hello, We try to make a small flying robot (ca. 20cm wingspan) and need to measure the velocity of it (up to 4m/sec) with an onboard device. For now we use a propeller with hall-sensor but it's a not so nice solution. Does sbdy know a system on a chip that used e.g. Hot wires? that can be used?
(Weight is a real constrain...)
United States - Member - New Member Engineering Fields - Chemical Engineering - New Member Hobbies - Musician - New Member
Re: Hot wire for small robots
04/03/2007 9:01 AM
I used to do work with hot-wire velocity measurement. There is an empirical correlation - King's Law - between velocity, fluid properties and probe geometry.
I did a search and found this:
http://ieeexplore.ieee.org/Xplore/login.jsp?url=/iel3/3573/10682/00496325.pdf?isnumber=10682&arnumber=496325
If that doesn't give you what you need, you will have to go the DIY route.
If I remember correctly, you should be able to program a small microprocessor to give the velocity from hot wire and temperature inputs and a measured current output using the King's Law correlation.
Good luck with the project!
Regards,
Mike
"Blessed is the man who, having nothing to say, abstains from giving us wordy evidence of the fact." George Eliot [Mary Ann Evans] (1819-1880)
04/04/2007 12:38 AM
Dear Guest,
So - was this any help - or what? It really is nice to know that when you reply to a post, it has some usefulness.
Mike
04/04/2007 2:10 AM
Unless relativity is achieved solution is power consuming or weight constarint will come.
Regards
Srinivas
Have you considered a GPS device?
04/04/2007 4:37 AM
thank you for the answers, however there is no way for us to develope such a device ourselves, actually we're trying to find a solution that is simple to use, small and light weight. But the only thing there is on the market seems to be this: http://www.c2v.nl/fr_index.shtml?/products/sensors/air-flow-sensor.shtml
but it is not available anymore...
does sbdy know another manufacturer or a competitor product of this.. (a bit smaller would be even nicer )
Thanks a lot!
mirko
Good Answers: 183
04/04/2007 12:16 PM
It is very simple if you do not want to have a high precision. You need two resistors one for measure one for a reference and an OP AMP to generate a constant curent through the measuring wire. The tension at the op amp output is proportional to velocity. The relationship between curent and velocity is not very linear since it depends on the forced or free convection between wire and air. Without a calibration you will only have an indication but you could not use the signal for more than a rough regulation.
Good Answers: 183
04/04/2007 1:08 PM
May I also suggest a pitot tube similar velocity measure .
There are very small pressure transducers which can be used as difference to determine the pressure drop due to displacement. It could be easier to manage than the hot wire approach. The response is also not linear but much more possible to approximate with a simple function (second degree function drop to velocity)
One of the transducers should measure the stall pressure with its sensitive opening toward the direction of flight and the other at 90°. Since the sensitivity is important it is possible to use the signal with a low amplifier gain. Impedances are high so that curents are small. For the hot wire system you will need more curent.
04/04/2007 4:39 PM
What is the max weight you can afford to carry? There are light weight hand held wind speed measuring devices some are no bigger than a small mobile phone. Just make sure it has a data logger inbuilt and a USB socket.
There's them that knows and them that just thinks they know, whitch are you? Stir the pot and see what rises up. I have catalytic properties I get a reaction going.
04/11/2007 6:23 PM
thanks you all for the help!
we'll try the hot wire sensor...
I'll let you know about what's our feeling once we receive a demo of it...
M
Anonymous Poster (3); BrainWave (1); Mikerho (1); mikey (1); nick name (2)
