How can a geographical cordinates of a place or a geographical position be converted to a Azimuthal cordinates? I mean converting Longitude & Latitude of a geographic position into false Northing & false Easting.
Yes, but there are hundreds of ways to do this depending on the map. If you are simply looking for global coordinates, then you must select the format you want. The most popular is WGS-84 (World Geodesic Survey in 1984, if memory serves).
You can also do three dimensions with altitude above the geoid. I would suggest looking for some professional white papers on the subject.
You should also look at the projection used for the map.
The best advice is to look for a GIS crowd (for example ESRI)
I did a MSDOS converting program 15years ago and could accommodate most of the projections (Albers, Lambert ..... ) but it was based on Clack 1888. I did not convert it to WGS84 yet.
