Previous in Forum: Induction Motor Drives   Next in Forum: CFL Motion Activated Lights
Reistance
02/18/2011 8:38 AM
Resistance (R) is proptional to 1/Area (A).For a thin wire of length l Resistance would be very large and no current should flow.Then why a thin wire melts or burns when voltage is applied.
Re: Reistance
02/18/2011 9:07 AM
Because the other name of voltage is pressure.
Good Answers: 119
Re: Reistance
02/18/2011 11:06 AM
For current to be "0", the voltage must be "0" or the resistance must be "infinite".
I=V/R
Some current can still flow through a thin wire. When it does, there will be some joule heating (I^2 *R).
Re: Reistance
02/18/2011 11:07 AM
<...why a thin wire melts or burns...>
It's the heating effect in the wire: the heat dissipated is the square of the current multiplied by the resistance.
It's the principle behind the fuse.
Re: Reistance
02/18/2011 12:33 PM
H=I^2Rt
where
H=Heat
t=Time
Anonymous Poster (2); mjb1962853 (1); PWSlack (1)
