Previous in Forum: What is the Best Material for Filtration in Hot Air Ducting?   Next in Forum: Lead
Inconel and Ammonium Hydroxide Compatibility
02/18/2011 9:33 AM
I need to know if Inconel x750 is compatible with 29% Ammonium hydroxide. If so, where is the actual proof?
Re: compatibility
02/18/2011 10:05 AM
Thanks. I searched, what I thought was everywhere, and couldn't locate. You have been a great resource.
Good Answers: 48
Re: compatibility
02/18/2011 10:11 AM
There are many material compatibility charts available online (do a google search). It is worth cross-checking between two or three of them, rather than relying on one.
You need to be clear in your mind what you mean by compatibility. Is any corrosion permissible? If so, what is the permissible corrosion rate? Charts often don't show this, but a corrosion rate that is acceptable for a centrif pump or pipework would not be acceptable for equipment with close-running clearances, eg side-channel pumps, gear pumps & mech seals.
You might be hard pushed to find anyone who will give you actual proof. NACE (National Association of Corrosion Engineers) used to do a very comprehensive book that gave actual corrosion rates for a wide range of materials and fluids. To be sure, you might want to do a dip-test yourselves.
Re: Inconel and Ammonium Hydroxide Compatibility
02/18/2011 11:01 AM
The Cole Parmer materials compatibility database.
Good Answers: 48
02/18/2011 11:10 AM
That's one of the ones I tend to use. Quite comprehensive.
02/18/2011 11:45 AM
I just went on Cole-palmers site and they don't list Inconel x-750. An answer was found www.balseal.com. Tech library - Tech reports - TR-60C
Holzfeller (2); mike j (2); PWSlack (1)
