Backup Rolls are used in Big Steel Rolling mills and are really costly. One Backup Roll costs upto $100,000. They are at present in short supply. I think we can reuse the Rolls with damaged barrels by machining the barrel diameter , grinding it to great tolerances and then fitting a new sleeve with same I.D.as O.D. of the Barrel. O.D. of the sleeve will definitely be the original O.D. of the Roll Barrel. Fitting will be done by shrunk fitting. I suggest using Sleeve of ASTM 52100 or X75 alloys. I suggest using of Centrifugal Cast Sleeves. Requests for sound practical advice . Jay Sureka
