Previous in Forum: Lead   Next in Forum: Trying Industrial Chemical Dyes at Home in my Lab
21 comments
Melting Silver
02/20/2011 5:03 PM
I'm trying to make a silver casting. I've done it before, but I think it was probably more luck than anything else. For some reason that eludes me, I just cannot get the silver melted... A crucible, with 125g of clean (sterling) silver, direct from the refinery. A LPG gas torch, with it's biggest nozzle fitted. The (fireclay) crucible is placed on top of a fireclay block. My reference: Jewellery Concepts and Technology by Untracht. I'm obviously not understanding something about the physics at work here. I've got a large flame, and adjusted the (atmospheric) air intake ring so that the yellowness of the flame, just disappears. I believe I've then got a "reducing flame" which is what I think I need. Then, I've managed to heat the lumps of silver in the crucible to a point where they have sort of fused together. If I keep the flame on there for about 10 minutes, I can get the silver glowing red hot, and the flame creates a shiny liquid look where it touches the metal.... but that's it. So why won't the metal melt? 1. Maybe too much metal? 125g and LPG is just too much - I need Oxy-Acetylene? 2. Firescale is now present, and acts as an heat shield? 3. I've got the flame anatomy wrong? 4. My silver is not. I've been sold something else? Can someone put me out my misery?
Re: Melting silver
02/20/2011 5:52 PM
maybe you need MAPP gas rather than propane? It burns hotter.
Re: Melting silver
02/20/2011 6:25 PM
OK.... but I don't know if my local filling station would know what to do if I walked in with my cylinder and send fill it up with MAPP please. Where does one find it?
Re: Melting silver
02/20/2011 6:20 PM
Make sure the crucible is heated as well as the silver. The material of the crucible may not conduct well, but there's quite a lot of it - so it has a relatively large ability to soak up the heat applied to the silver (it's a function of actual mass and heat capacity of the crucible).
Re: Melting silver
02/20/2011 6:35 PM
Yep, done that. The semi fused lump of silver has formed an irregular cup shape which I can turn over in the crucible. I am then able to apply the flame to the metal, and the crucible surface containing it. I get the flame coming back up around the metal so the entire thing is getting heated. After a good amount of time - like minutes - it still isn't even like bad rubber. I can make the crucible surface glow red too - takes a bit of time, but doesn't change anything. Right now, I'm thinking Oxy-Acetylene is the only option...
Good Answers: 130
Re: Melting silver
02/20/2011 6:21 PM
I think you need a flux
Re: Melting silver
02/20/2011 6:36 PM
The flux is in there... (Sorry, forgot to mention it). Sprinkled on top when it's hot and red.
Good Answers: 130
Re: Melting silver
02/20/2011 8:07 PM
I gave you the link to read and contemplate the principals of smelting.
It's my nice way of avoiding saying "you are doing it all wrong"
Re: Melting silver
02/20/2011 9:44 PM
It should be spelled principles.
Good Answers: 130
Re: Melting silver
02/21/2011 7:14 AM
Well I see by your subsequent posts - you at least read the link. And might have realized he's oxidizing faster than melting because of his methodology.
Re: Melting silver
02/20/2011 7:12 PM
Just a guess on my part, do you have the flame blowing around the crucible or is the the tip of the flame just under the crucible?
Re: Melting silver
02/20/2011 7:27 PM
Think the torch is above the crucible, and directed into it (OP states "The (fireclay) crucible is placed on top of a fireclay block.").
Re: Melting silver
02/21/2011 7:59 PM
Flame is blowing into the crucible. The lump of non-melting silver is wedged in the crucible, making space for the flame to pass all round.
Good Answers: 146
Re: Melting Silver
02/20/2011 8:18 PM
125 g is 4 ozt that is a lot of silver, plus your fire clay absorbs a lot of heat, and heat is being lost all around if you do not have a setup to reflect the heat back, as in, arrange your bricks around the crucible being heated. You may also get more heat from the setup if you can raise the crucible off the firebrick by an inch or two on a tripod. The brick below it is adding all its weight to the amount of heat required for the operation.
Besides raising up off the brick (which will make a huge difference) you might also consider whether the casting can be made by melting smaller amounts at a time (I don't know how this would affect the casting).
I wouldn't worry about it not being silver - it sounds like silver behavior with not enough heat, to me. Forget about firescale it will not prevent melting.
incus opella
Re: Melting Silver
02/20/2011 9:03 PM
My sister-in-law does jewelry, and use an air-acetylene torch. You can do oxy-acetylene with a soft flame, too, but it might still be overkill.
Re: Melting Silver
02/20/2011 10:12 PM
What kind of burner exactly are you using? If your gas flow is limited, the flame may not be sufficient to melt the amount of Ag that you have. Know also that the many tries at doing this, as I surmise from your description of the problem, has made a significant amount of Ag2O - silver oxide. This will interfere with the melting process as well but, if you can get enough heat to the crucible, your silver will indeed melt and the Ag2O will rise to the top and can be separated by decantation - the unwanted oxide is called dross.
Flame temperatures of a few fuels:
  • 2200°C = 3992°F, for Propane/Oxygen
  • 2927°C = 5300°F, for MAPP Gas/Oxygen
  • 2700°C = 4892°F, for Acetylene/Oxygen
  • 3200°C = 5792°F, for Hydrogen/Oxygen
Since the melting point of Ag is 962ºC, well below the flame temperature of even Propane/Oxygen, you just need a bigger flame.
Re: Melting Silver
02/20/2011 11:55 PM
My burner is a LPG bottle (Propane / Butane I presume) connected to a torch (without a regulator). The brand name is ORCA (see here: http://www.regal.co.nz/category.php?sub_id=189). It is atmospheric oxygen - not pure, so my temperatures are not quite that hot. I'm going to purchase a torch that will give me (bottled) oxygen to add to my LPG gas, and then my temperature should be much higher.
Re: Melting Silver
02/21/2011 12:14 AM
Let us know how you get on then. Always good to see success!
Re: Melting Silver
02/21/2011 8:02 PM
Well, I've got my dual gas torch now. Just waiting for the paperwork to go though with the gas company so they'll sell me the oxygen. The guy I bought the torch from says that he does it all the time with LPG/Oxygen mix, and trying LPG alone is a waste of time. So it looks like I'm on track. I'll let you know how it goes. Thanks. Michael
Re: Melting Silver
02/24/2011 6:10 PM
Success! Took a while for the gas company to process my account application. Apparently, the accounts department is in Christchurch, which is a very traumatised place at present. I also had to increase the size of my torch flame, with a different tip. The metal heated to red fairly quickly, and then it took a fair bit of time to heat the crucible and metal to a point where it actually began "dripping" into the bottom of the crucible. I'm amazed at the amount of energy one has to "invest" in the metal and crucible for it liquefy. The other interesting thing about this is that an open mould casting doesn't work, because like any liquid I suppose, surface tension comes into play, and the liquid silver also forms puddles with gaps in between. Thanks for the conversation everyone. Cheers Michael
Re: Melting Silver
02/24/2011 6:33 PM
Glad to hear you've got it sorted out.
BTW - why not register? You can get e-mails to let you know when someone posts on at thread you've subscribed to if you want, and keep track of such things using the "updated discussions" link (looks like this: ).
Also sure lots of folk here would love to see examples of your work - you can post pics if you register.
Jus' sayin'.
PS Sympathies if you have any friends or rellies in Christchurch. Bad.
Re: Melting Silver
02/24/2011 7:54 PM
Agreed on all points. Particularly the invitation for Michael to join our merry band of pranksters and for anyone having to deal with the tough times in Christchurch.
Reply to Forum Thread 21 comments
34point5 (3); Anonymous Poster (7); artsmith (1); JohnDG (3); Mikerho (3); redfred (2); Tornado (1); user-deleted-1105 (1)
