Previous in Forum: Query on Frequency   Next in Forum: Transformer and Motor Windings
Induction Motor Testing
02/21/2011 6:36 AM
Dear Sir,
I am making 3 phase induction motor test bench which will be intended to test 0.37kw to 30 kw motors. Test to be conducted are
i) Insulation test
ii) High voltage test
iii) Winding resistance test
iv) No load test
v) Block rotor test
Can any one suggest me the procedure to follow to conduct the above mentioned test
What will be the Pass fail criteria for all the above test
I need help very badly.
Re: Induction motor testing
02/21/2011 7:12 AM
You are stuck very badly..,!
Reply Score 1 for Off Topic
Good Answers: 181
02/21/2011 7:59 AM
For you to have asked the questions I don't think you should even consider building your rig. You're not competent.
Sorry to be blunt, I'm just considering your safety.
In my last job I had a 250KW test bed, all the electricians were trained to use it!
Re: Induction Motor Testing
02/21/2011 10:43 AM
Er, the tail is wagging the dog here. If the tests are not covered by requirements, then how on earth is it possible to write a procedure that will cover the requirements and the pass/fail criteria <rhetorical question>?
Which is another way of saying, let the requirements dictate the procedure and the criteria. So, what is driving the need to establish such a facility, and what does it ask for? Once that has been established, the procedures and pass/fail criteria can be determined from the established requirements.
The help comes from the Client, not CR4.
Anonymous Poster (1); PWSlack (1); TonyS (1)
