Previous in Forum: Fire Water Line Cathodic Protection   Next in Forum: Aluminium/Nitrigen ration
316SS Ti in Thermowells for Sulphur Plant
02/21/2011 9:18 PM
My customer is asking me for thermowells made of 316 SS Ti for Sulphur Plant, the conditions are Pressure 4.1 kgf/cm2g , Temperature 260/350 degrees (500-662 F), however it is dificult to find this material, I need to know if it is possible to recommend just 316 SS for this apllication , this is for TiO2 bed. Thanks.
Pathfinder Tags: 316SS Ti
Re: 316SS Ti in Thermowells for Sulphur Plant
02/21/2011 10:34 PM
02/21/2011 11:50 PM
Thanks Tornado, I'm going to contact them and I'll tell you my comments.
02/22/2011 12:47 AM
It looks as though the addition of Ti improves both the temperature performance and corrosion resistance, which sounds like the ticket for this app. Thermowells would probably be machined out of bar stock, if 316SS-Ti is made in that form.
02/22/2011 10:30 PM
The application as I understand is for the Catalyst bed in the Convertor of the Sulphur plant. SS 316 / 316L is normally used in most plants.
"We have a right to be wrong in our opinions, but we have no right to be wrong in our facts"
03/09/2011 5:36 AM
Hi , this is interesting for me as I would like to know also the installation of the instrument in the catalyst bed. I would be grateful if you have more in depth info for my information.
rise and rise again...continue to learn is nothing wrong
02/23/2011 3:46 AM
I recently had this question asked. 316Ti is better at higher temperatures than 316L - in my situation the question as to replace 316L with 316Ti. Given the temperatures involved it would not make any difference which material you choose for this application.
I would suggest that you contact someone like the BSSA (British Stainless Steel Association http://www.bssa.org.uk/) or whichever association is in your area. If you give them all the details then they will be able to assist you - that would be much better than getting advice from unknown sources in the internet.
02/23/2011 9:52 AM
In some instances you could use a 316 SS with a ceramic outer layer, it is not the same and you would have to analyze the real life expectancy of the material when in use.
Register to Reply 7 comments
Anonymous Poster (1); Tornado (2); TWDIANA (1); vargaalex (1); yatvsh (1); zhafir (1)
