Previous in Forum: How Do I Mantain Even Deposition During Electroless Nickel Plating   Next in Forum: Music Wire vs. Stainless Steel Springs
PN ratings V/s ASME Pressure Ratings
02/22/2011 11:25 PM
Is there any connection between PN ratings like (16, 20, 54 ...) with ASME pressure Ratings (150#, 300#....). and what does PN16 represent??
david_james
Good Answers: 48
Re: PN ratings V/s ASME Pressure Ratings
02/23/2011 4:54 AM
PN16 means rated for 16bar.
ASME 150# (or ANSI 150) means rated for 150psi.
Good Answers: 299
02/23/2011 5:20 PM
"PN16 means rated for 16bar."
Is that bara or barg? I would guess bara...
I got a gauge question wrong the other day
Good Answers: 48
02/24/2011 3:31 AM
No, I would say bar or barg.
Usually if absolute or gauge is not specified you can assume it is either gauge pressure (In which case perhaps it should really be stated, rather than just assumed) or differential pressure (in which case absolute & gauge don't apply). In the case of pressure ratings for flanges, vessels or pumps, you are really rating the differential pressure, inside vs. outside, so strictly speaking it should just be bar, but since the outside is usually atmospheric (0barg), then you could also call it barg.
I hope this makes sense. There is a lot of room for confusion and misunderstanding in absolute and gauge pressures, particularly regarding pump suction where terms such as 'suction pressure', 'suction head', 'suction lift' and NPSH are thrown in.
02/24/2011 2:42 AM
No, it doesn't. Not without a temperature criterion, anyway.
Good Answers: 48
02/24/2011 4:00 AM
You are absolutely right, the pressure rating means nothing without temperature, and what I really should have said is that these numbers relate to the pressure rating. Following is a chart of pressure/temp ratings for flanges to ASME/ANSI standards, and as we can see, 150# flanges are rated for anything but 150psi.
Gage Pressure
(psi)
Temperature Flange Class
(oF)
15030040060090015002500
< 1002857409901480222037056170
2002606759001350202533755625
3002306558751315197032805470
4002006358451270190031705280
5001706008001200179529954990
6001405507301095164027354560
6501255357151075161026854475
7001105357101065160026654440
750955056701010151025204200
80080410550825123520603430
8506527035553580513402230
900501702303455158601430
95035105140205310515860
1000205070105155260430
Doorman (1); Holzfeller (3); PWSlack (1)
