Previous in Forum: mccb & mcb   Next in Forum: Batteries Calculation Design
Purpose of Resistance With Inverter
02/23/2011 4:44 AM
I have seen many inverters connected with an external resistance called "re-generative resistance". I want to know the purpose of this resistance and what is the meaning of re-generative.
Sorry if a basic question.
Re: Purpose of resistance with inverter
02/23/2011 4:56 AM
never be sorry to ask anything. we must not be shy or feel sorry to ask for either food or knowledge.
A load connected to a motor has kinetic energy when rotating, and potential energy when it is located in a high position. When the motor decelerates, or when the load descends, the energy is returned to an inverter. It is known as regeneration, and the energy generated by the phenomenon is known as regenerative energy.
Importance of Braking Resistor
If the regenerative energy generated in deceleration or descent in an application is too great, the main circuit of an inverter may have an increased voltage and it may be damaged.
Because the inverter usually contains the overvoltage LAD stop function, it is not actually damaged. However, the motor stops detecting an error, making a stable and continuous operation disabled. Therefore, you must discharge the regenerative energy outside of the inverter. thus we connect a resistor which dissipates the excess energy in the form of heat. we call that resistor as regenerative resistor or braking resistor.
02/23/2011 7:10 AM
