Previous in Forum: Purpose of Resistance With Inverter   Next in Forum: Rating of Power Saver
Batteries Calculation Design
02/23/2011 5:33 AM
How we know how much batteries or DCvoltage require for differnt types of UPS ratings
Good Answers: 181
Re: Batteries calculation design
02/23/2011 5:43 AM
Ask the UPS manufacturers.
With the information you've given you can't expect an answer.
02/23/2011 6:11 AM
enen if we have 5 KVA UPS DC voltage require 108 V. But the same 5 Kva some manufacturers are using 430 V Dc also who will decide those things what is the factor to be considered
02/23/2011 6:41 AM
Study Ah of battery.
02/23/2011 6:46 AM
Talk to the UPS manufacturer.
Good Answers: 53
02/23/2011 7:06 AM
For same power ratings you can have different input voltage requirements, if you choose lower input voltage AH rating of battery required will be higher, with the law of proportion.
Energy required to lift 10kg stone to 1 meter height= Energy required to lift 1kg stone to 10 meter height, (g is constant)
Note- in general higher input voltage UPS are more efficient,
Good Answers: 116
Re: Batteries Calculation Design
02/23/2011 6:24 PM
Adding to post #5, higher voltages make the UPS more efficient. The cost of a given watt-seconds capacity in a battery of a type is usually lower with a smaller number of cells - there is less weight and space used on casings and interconnections rather than plates and electrolyte. This has to be balanced against the economies of a higher voltage and the possibility that a higher voltage system can be more powerful and more efficient.
02/25/2011 8:08 PM
battery rating is determined by its voltage output and the amp-hour capacity, likewise your design must be made in the needed outputs mentioned above...the ones that matter later on is with the ampere output of your charger which supplies your components on a normal basis...your battery automatically take over when charger input is out...
take care of your seconds and the minute will take care of itself..
Register to Reply 7 comments
67model (1); Anonymous Poster (1); PWSlack (1); rakesh_semwal (1); rockraiden (1); TonyS (1); vaithilingam (1)
