Previous in Forum: Stainstess Steel Chemical Reactor Finishes   Next in Forum: Measuring Buttress Thread
Hydraulic Accumulator
02/23/2011 1:34 PM
Hello Everyone,
Im doing my own calculations for my research project related to hydraulic accumulators. I want to use the hoop stress equation to find out an approximate mass of the accumulator. The problem is that I dont know whether hydraulic accumulators are treated as thin walled or thick walled pressure vessels. The accumulator that I want to use will be subjected to max internal pressure of 200 bar. Please tell me whether I should treat it as thin walled or thick walled pressure vessel and a possible resource for this as well for reference. Thanks in advance!
Re: Hydraulic Accumulator
02/23/2011 5:35 PM
As I recall, if D > 10t, it's thin-wall. You could try the thin-wall formula first, giving a preliminary ratio, and then go to thick-wall if needed.
02/23/2011 5:39 PM
Thanks, but I have already carried out using both. I want to know by which approach the commercially available accumulators are designed.
02/23/2011 6:13 PM
Well, was D > 10t, D < 10t, or (unlikely) D = 10t?
Or maybe phone up Parker or somebody, and just ask? (No guarantee they'll say....)
Good Answers: 137
02/24/2011 5:41 AM
Using design stress 100 MPa (fairly conservative due to nature of application), r/t = 100MPa/20MPa = 5, so D/t =10, bang on the crossover point! I'd be inclined to calc it both ways and use the thicker.
Also it will see pressure cycles doing its job, so I'd think a cyclic stress/fatigue calc is required. Depending on frequency/design life, this could make a big difference.
Cheers..........Codey
02/24/2011 5:55 AM
Thanks Codemaster, thats a big help!
Cheers!
Good Answers: 204
02/26/2011 11:35 PM
Accumulators come with manufacturer pressure test certs (ie, tested to 6000 psi, and therefore rated for operation to 4000 psi) (1.5 x operating pressure)
no calcs necessary. you select based on the operating pressure of your system.
Chris
Register to Reply 6 comments
Anonymous Poster (1); chrisg288 (1); Codemaster (1); Tornado (2); zealous131 (1)
