Previous in Forum: Indicator Lamp in Series With a Switch   Next in Forum: Remote control gas oven for greenhouse in frozen weather
13 comments
Megger Value of motor
02/24/2011 3:49 PM
Dear All,
Kindly tell me the normal megger value of insulation of motor? Does it depend on voltages of the system or KW rating of the motor?
Re: Megger Value of motor
02/24/2011 3:53 PM
Is it giving several types of earth fault - a clockwise earth fault and an anticlockwise earth fault, for example?
02/24/2011 4:01 PM
it is giving slack fault indeed
02/24/2011 4:05 PM
Would that be the directional fault that answers the earlier question?
02/24/2011 4:12 PM
Dear PW Slack,
We are using 7sj602 relay for HT Incoming and Out Goings at 11 KV. This relay gives us i> , i>> and i>>> Also IE>, IE>> and IE>>>. For IE, it represents the earth fault current. When we consult the manual of this relay, there are two distinguished types of fault currents. These are Directional and non-directional earth fault. My previous question was about this matter. Now this question is about Megger Value calculation. We are using the pet formula of 2 M Ohms for insulation at 400 V. While for 11 KV, we take the insulation level of 12 M Ohms and greater. I have to verify and discuss with the experts here.
Regards,
02/24/2011 6:17 PM
What is the earth fault protective device set to trip at?
02/24/2011 4:07 PM
As a rule from practice: minimum acceptable insulation value is 1 kOhm per volt, example - 440 v supply voltage - 440 kOhm minimum insulation resistance (if higher, better).
Regards
02/24/2011 5:10 PM
For motors rated more than 600v minimum acceptable insulation resistance is 30 M ohm at 40 degree C (cold), when stopped after running (hot) 10 mega ohm is the minimum.
You have to apply temperature correction if temperature is other than 40 deg C.
Dear AA in your previous post I think you have created confusion by using term "directional" but rather I try to clear the matter right there.
Knowledge sharing is a WIN-WIN situation
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Mechanical Engineering - New Member
02/24/2011 8:38 PM
IR result must be in unit of MEGA OHM..Not depend rating of motor
One system
Good Answers: 244
02/24/2011 9:49 PM
The minimum insulation required depends on voltage, not the KW (or HP) of the motor.
Minimum insulation (Mega-ohm) required is KV + 1.
See these links:
http://cr4.globalspec.com/thread/56906/Insulation-of-a-Motor
http://www.megger.com/common/documents/Above1kV_UG_en_V04.pdf (page 25)
- MS
02/24/2011 11:15 PM
AC Motors, 75°C 120-volt - 1.12 megaohms
208-volt - 1.20 megaohms
240-volt - 1.25 megaohms
480-volt - 1.50 megaohms
DC Motors, 75°C All voltages - 1.00 megaohms
High-Voltage Circuit Breakers, 20°C 10,000 megaohms
High-Voltage Bushings, 20°C 10,000 megaohms
Insulated Cable - Varies as a function of type and thickness of insulation; see ICEA Standards
Transformers, Oil-Filled, 20°C
Where:
E = Voltage rating of winding under test
kVA = Rated capacity of the winding under test
Transformers, Dry type, 20°C, where E and kVA are as defined above
Other Equipment - Refer to Manufacturer's Data
You don't understand anything until you learn it more than one way.
02/24/2011 11:26 PM
sorry for missing the formula
1.5E/SQRT(KVA) for oil filled
30E/SQRT(KVA) for dry type
02/25/2011 1:38 AM
above1000 Mohm, it doesn't depend rating of motor only depend warnishing and enamal coating of wire.
Good Answers: 170
02/26/2011 1:43 AM
Refer to IE Rule No. 48 ans IS 732 if you are from India.
Register to Reply 13 comments
AA (2); Anonymous Poster (2); electricalexpert65 (1); loadshare (1); mountk2 (1); msamad (1); PWSlack (3); vijaymail_electrical (2)
