Previous in Forum: Ground Bed   Next in Forum: One 75-Watt Bulb
Design of Overcurrent Relay
02/26/2011 2:52 PM
Can someone out there help me design an overcurrent relay to protect a welding transformer whose load current measured through a C.T (current transformer) shows 2 amperes on secondary side of the C.T?
New Zealand - Member - Kiwi
Good Answers: 29
Re: design of overcurrent relay
02/26/2011 3:54 PM
The simplest and surest way to protect your welding transformer is with a circuit breaker, either an MCB if your welder draws less than 63A or an MCCB if it draws more. The effort and cost involved in using the CT will almost certainly be greater for no real advantage.
paulusgnome
Good Answers: 181
02/26/2011 4:13 PM
What sort of O/L do you want, thermal or instantaneous?
03/02/2011 9:19 AM
thermal overload.
11/22/2018 9:27 AM
There's no point in designing one when numerous temperature-operated switches and relays exist on the open market already. An internet search engine will reveal them and then all that is needed is the correct selection of one that is suitable.
Register to Reply 4 comments
guruprasad (1); Paulusgnome (1); PWSlack (1); TonyS (1)
