Engineers,
I have this challenging problem and I need your help!
As you can see in the pictures, we have a Volume which is thermal isolated; only the side walls can transfer heat. This Volume is located in an environment with air (180 degC).
Inside the Volume (filled with air) we have a copper plate. This plate can be heated up, because of the heat which coming through the side walls. Our task is to cool that copper plate. To do it we place a pipe inside the volume. Through the pipe a cold fluid flows.
We know all the parameters of the gas, fluid, plate and pipe. We also know the entrance temperature of the fluid in the volume Tf1. The radial heat transfer trough the pipe can be neglected, because the thickness of the pipe wall is small.
The Goal is to calculate the mass flow rate in the pipe which is needed to keep the copper plate at constant 150 degC.
I am really confused how to do it.
- We have a heat Q1 coming from environment inside the Volume.
- We have free convection of the air on the copper plate and free convection of the air on the pipe.
- The fluid will be warmed up, by flowing through the volume. As far I understand, to perform a best efficiency the exit temperature Tf2 of the fluid should be higher, right?
- This is unsteady state, right?
So, how to do it? How to start? What to calculate first and how to come to the mass flow???
I appreciate any help! Thanks
