Previous in Forum: vt and ct burden calculation   Next in Forum: ug cables
Good Answers: 12
Is Laminated core compulsory?
03/01/2011 12:51 AM
Transformers are made of laminated core to prevent eddy current losses. If I use the "E" core on vibratory feeder bowl then why should I use laminated core? why not solid Iron?
Subramanyam
Pathfinder Tags: Vibratory Feeder Bowl
Good Answers: 181
Re: Is Laminated core compulsory?
03/01/2011 2:18 AM
Nothing to stop you, it just won't be very efficient.
Good Answers: 170
03/01/2011 3:21 AM
Not mandatory, as far as you can afford the additional costs due to increased eddy current losses and pre-mature failure due to increased eddy current heating in the solid core.
Good Answers: 12
03/01/2011 4:30 AM
Both of you thanks. I am facing frequent breakdowns (once in two days) as core is opening breaking best riveting/ welding. I am already using this at 25% (max.) efficiency. Hence I shall try with solid material and shall give you feedback.
Subramanyam
Register to Reply 3 comments
electricalexpert65 (1); kvsubramanyam (1); TonyS (1)
You might be interested in: Parts Feeders, Core Shafts and Mandrels, Core Modules
