Previous in Forum: ABS Rules   Next in Forum: comparision of 11KV & 6.6KV
d.c.motor
03/01/2011 4:23 AM
is a 4 point starter starts a d.c. shunt motor.if yes then why?
Good Answers: 53
Re: d.c.motor
03/01/2011 4:50 AM
Sorry I think you missed the way to your examination class, BTW this is CR4 and you are welcome here, Now can you please rephrase your Question?
Good Answers: 116
Re: d.c.motor
03/01/2011 6:05 AM
The number of steps of armature resistance for starting a DC shunt motor depends on
  1. Internal Armature resistance voltage drop at rated current as proportion of supply voltage.
  2. maximum permitted peak armature current during starting as proportion of rated current.
If 1. is high proportion e.g. 0.15 [small motor] and 2. is big e.g. 2.5 In then 2 stages may be enough, but 3 or 4 stages or more are common if limit is 1.6 In with bigger more efficient motor.
You might be interested in: DC Motors, Shunt Resistors, DC-DC Converter Chips
