Previous in Forum: Manpower Supplies Quotation   Next in Forum: Washing Machines
32 comments
Hobbies - Automotive Performance - New Member
Light Power Cell System
03/07/2011 2:36 PM
Light Power Cell System http://t.co/xE4h1bY
Head on over to the GE challenge and post your vote for this one.
I too have taken part in the GE ecomagination Powering your home and enetered the LIGHT POWER CELL SYSTEM or LPCS and prototype as my submission.
My work has been in the study and application of capturing spent artificial light energy and reusing it by a systematic capturing of the spent artificial light energy and converting it to electricity. The amount captured is dependent on the number of Light Power Cell Systems placed in a system. These systems can work independently or on a broader scale to business, Hospitals and State, Government and local offices. Places where lights are on 24 hrs a day.
LPCS has no where to go but up.
"No where to go but up, LPCS". "One things for sure theres always two"
Re: Light Power Cell System
03/07/2011 3:02 PM
Have you actually done any studies of the amount of "spent artificial light energy" your system could capture and the amount of electricity you could generate per some unit of surface area?
I'm also having trouble with the term "spent" in connection with artificial light energy.
"Spent" artificial light would have no energy. "Reflected" artificial light would perhaps produce some small amount of electrical energy, but I don't see any pay-off.
Or, am I getting ahead of the game?
03/07/2011 4:58 PM
Actually, spent is an improper reference when it comes to the light its self, our pockets feel it tho as spent, right. So recovery of the light is all profit. The ROI is the question. Strength is in numbers and the more LPCS in place then the higher the useable current the greater the value of the energy. OK! Now the surface area is small per LPCS, cost is low. That of course is for now in the prototype I have displayed. Other ways of applying the cells and type of light fixture there will be different amounts of energy available. For instance LED is more powerful then Fluroescent. Incandescent and higher wattage bulbs like Mercury vapor and so on, the more power available with even less amounts of cells. Placement has to be close to the source but not blocking or obstructing the light on its intended area of coverage.
I see what LPCS do every day and have tested evry type of light, ok maybe not everytype, but have seen the capabilities. Especially in the 24hr per day environments. If you hold a dollar in front of you and turn on a light then leave the light on and take the dollar away then you see what we do every day of our lives. Now put back a portion in front of you say 10 to 20%. The last thing for this comment I will say isthis. No where to go but up. As technology improves so will the LPCS. If we don't do this then we are wasting dollars each year.
Thanks for the questions and the next time a department store is visited, look up and be amazedof what can and will be done with all the light.
LPCS / Gary
Good Answers: 114
03/08/2011 12:00 AM
I just joined the GE site & will be "voting" for all these 1/2 arsed ideas :D
03/07/2011 4:44 PM
But...
If you succeed in higher efficiency, won't your device just soak up all of the light?
I forgot to check the LynDoor™ Industries catalog before I posted. They probably have these already.
03/07/2011 4:58 PM
Don't you remember, we had to discontinue the LynDoor Industries™ Black Hole® Generating system before it ever went into production. It kept sucking all the light out of the fluoroescent light tubes in the office.
Of course, if it's dark there is no "spent artificial light" to capture.
03/07/2011 5:25 PM
HAHAH NO I am not wrapping the entire light with it, all though I had thought about it.
Efficiency to me means the light capturing devices able to do a better job converting the light sent there way with the same amoiunt of light. Reflection of the light happens anyway due to the surface of the thin film cells having a glossy surface. I can aslo use mirror film covering the cells and do a better job reflecting useable light and allowing light to pass through the film and using it too. How much better can I get, well that depends on technology, no where to go but up. Gets better everytime.
Tell me more about the catalog if you would be so kind.
LPCS
03/07/2011 5:34 PM
Gary, why are you not telling us about your patent application?
I will allow my partner lyn to tell you about our catalog: I am in R & D. I come up with crazy ideas, he finds us pigeons potential customers. Actually, we both come up with some pretty crazy stuff!
03/07/2011 6:27 PM
I have a Patent and a Patent pending that may be dead. The pending patent is my fault for not finishing but my first one cost me an arm,a leg and other life things, like money. So I have not pursude it furhter. The first patent is all about a device to control the media input for children and anyone else neading control of. It is idle at this time, Light Power Cell System has to go on its own merit. If I don't do it somemone will in one form or other. need anything else? I come up with things that will help humanity and make me rich, lol.
03/07/2011 6:08 PM
Gary,
You'll learn very quickly that I speak my mind. It's put me on the naughty step more than once.
Why don't you just improve the present delivery system so there aren't all those excess, wasted photons bouncing around where you don't want them?
Then we wouldn't have to produce essentially redundant systems at the generator and the light source?
Doorman: Make a note to work on a photon trap. This waste light thing may actually come to something.
03/07/2011 6:11 PM
This will be ridiculously inefficient.
But then zero has no way to go but up, too.
03/07/2011 6:23 PM
"But then zero has no way to go but up, too."
Doorman, Tornado is perfect for our VP of Marketing position. With his type of presentation................But then zero has no way to go but up, too. :) That's LynDoor™ if I ever heard it!!!
03/10/2011 2:29 AM
I have already been marketing your stuff from time to time. Where's my commish?
But then 10% times zero sales = zero, so I guess I can't complain.
But then further, I can just manufacture these items on the side, and reap 100%
I ain't seen no patents yet, not even any joe.fordham "provisional patents."
Come and get me! (I need a neener-neener nose-thumbing emoticon, but I doubt the Admins would add one.)
03/12/2011 10:44 PM
I don't want to come after you, I want help convincing the world they need this..and make a ton of money doing it.
Good Answers: 54
03/07/2011 10:57 PM
You've got an interesting idea and ideas of similar worth have won awards in the past.
It would be interesting if you could do a few "back of the envelope" calculations using existing devices (perhaps sourced from "LynDoor Industries") and estimate what the cost and return would be.
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
03/07/2011 11:50 PM
I did do some calculations and did it on the back of toilet paper, you know the ribbed kind that had kinda orbital swirrels on it, Two ply 4x4s sheets displayed in inches of course.
Then My grand son had a runny nose so I hap hazardly used the piece of 4x4 toilet paper and some of the figures,,, not the swirrly ones but my calculations were slightly distorted. Not sure how I can get those back to normal but I tried a hair dryer to fix it. The calculations that is. anyway if store A had 4000 lights on the ceiling hung by suspeneded wires then each assembly would produce about 100ma. Then you take the 100 times 4000 and you get roughly 400000 ma. Now divide that by a 1000 representing 1 Amp and suddenly you have 400,,amps,,,,,,where was I,, oh yeah so the calculations would have been better on the "back of the envelope", but all I had was a 4x4 sheet of toilet paper slighty distorted. Some times I see better with the lights on so you see the more you have on the better I look. Right?I will be glad to talk about return another time when I can see claerly er...
03/08/2011 12:21 AM
How many volts is each LPC? How many per assembly? About how much money?
On a very casual search, I found some 4-volt PV cells for $1.84 each, with Isc of 100 μA (not mA). Actual current would be somewhat less with a realistic load resistance. If this is representative, your estimate may be off by a factor of more than 1000.
But I don't know what type of PV cells or similar you have in mind; you haven't really said.
Good Answers: 54
03/08/2011 12:22 AM
Good start.
Now, how big an area of PV cells do you need? Looking it up in a catalogue, I find a cell about 150mm square, cost about $20 will give that gives 100mA @ 6V in Full sunlight (typically 100,000Lux).
You'll have to add extra cells (x20) to cope with a typical office with fluroescent lighting (500Lux).
So, you're looking at something 2m x 2m costing $400 to get 100mA in a typical office .
You can multiply that by 4000 light fittings and add a bit extra for the associated wiring, maintenance etc and get a ball-park figure (you may need to get some more toilet paper).
03/12/2011 11:04 PM
see my sample belo and tell me what ya need to know!!! I paid $1.65 each and shipping was a screw job of 3.25. If i was to order a gazillion of em then maybe I would get a brake or two...I have a bright idea and you know it.
03/10/2011 2:13 AM
Here is an example Of LPCS. For explanations here it is, The thin film stips are .5 x 2.25" rated at 12 ma 4.25 volts. In this sample is two of these strips operating three green Jumbo led operating at max 3.2 volts and 20 ma each. Each spot light is a 12v dc or ac input mr16, one on left is 6w and the one on right is 3watt. Obviously the spot lights are run from external power supply but the battery and green lights is maintained and run by those two lights the thin film power film strips. I have more photos if you need them but here is an example of how well this is working and by the way the led spot lights are not affected in performance, at least as far as I can tell. The more LPCS I have in parallel the better the output. I hope this helps understand what I am seeing a little better.
Gary
Oh the cost of each thin film strip is about $4.50 USD and each spot light can be found for under $10.00USD. Battrey pack is optional.
Good Answers: 114
03/10/2011 9:58 AM
moving from marketing to examples is a step
where's the data?
stuff like lumens at the point of use?
may a side by side demonstration of a book on a desk
all factors equal: distance, reflector, input watts
in the example above what is the difference in price?
cost of operation?
Personally, I don't want green lights except when I'm driving :D
03/12/2011 10:42 PM
Did you see the sample thin film strip? The manufacturere says:
It says 12 ma at 4.10 volts. I am running three at 20 ma green leds and using two thin film strips. Isn't that like a mega bunch of suns worth at a small amount of capturing device and isn't that beyond the ARTIFICIAL light concept compared to our mighty SUN. I really get lost sometimes and need to find my way home...Green is good after all/
Each spot light is run by a 12 v a/c power supply so I have a hard time figuring input other than using my mapawatt meter. that is lying as it says i am using 7 watts for 9 watts of light..anyway...I really love this stuff as it amazes me everday.....
Good Answers: 114
03/12/2011 11:00 PM
If you can't design, carry out & document proper tests, how can you tell if the concept makes any sense?
03/12/2011 11:10 PM
You're right! I will do my best to do that, thanks.In my head and my daily workings I see the results, but on paper or to write it is hard to do. I hold high regard and respect to those that can do it in their sleep. I unfortnately have to work at it real hard on top of invisioning it and making prototypes that work. I see it why can;t evryone else??????Right!!!
03/08/2011 12:48 AM
The output will always be less than input. You must do an economic analysis over a period of time.
pnaban
03/08/2011 12:51 AM
I think you just did
03/08/2011 11:46 AM
How would you see this applying to the LPCS. Explain a bit.
I start with nothing and produce something. Thats more than anyone has done since Edison invinted it. In other words. we turn the light on and the light vanishes. As soon as you turn it off it has served its purpose. LPCS can take the energy, store it and release it later or somewhere else. For years we burned the lights and complained of the cost. Now I can change that, that has to be be good. LPCS is for humanity not against it.
LPCS /Gary
Good Answers: 114
03/08/2011 12:02 PM
This is not an technical explanation this is marketing
We deal in science & data for the most part on this site
03/12/2011 11:26 PM
for me I really don't care what the input is as we do it every day and we hate it. Turn the lights on then turn them off. I can reuse it over and over again. endlessly, somewhere physics or science or just plain sense is in my favor. I come out on top no matter how i see it...
03/08/2011 12:18 PM
As far as I understand it, most of the energy given off by most light sources is "Heat", if that could be captured and turned into electricity then it would be a good saving?
Xanasax
03/08/2011 12:49 PM
Where I live this heat is welcome as-is. Air temp right now is +40F, with a forecast low tonight at -150F.
Brrrrrrrr.
03/12/2011 11:02 PM
BRRRRRRRR is right or is it BBBBRRRRRRRIIIIIGGGGHHHHHTTT, anyway bright is good and light is bright,,,right....
03/12/2011 11:01 PM
True dat, however some light emitting devices are low heat, example is 40 watt fluroescent 4 ft tube ligths, very cool and very powerful lights if used with the right power cells. paint on would be best then all you have to do is replace a bulb every so often. Sorry but waste not want not... right or is it left. Amorphous cells is the way to go, did i say calculator!!!!!
Register to Reply 32 comments
Anonymous Poster (1); Doorman (3); ffej (2); Garthh (4); LPCS (13); lyn (4); pnaban (1); Tornado (3); xanasax (1)
You might be interested in: Cell Processors, Battery and Fuel Cell Components
