Previous in Forum: Laminated Core of Motor   Next in Forum: Reduced Neutral
11 comments
Conductor Size
03/08/2011 12:25 AM
How to decide the size of Conductor for Neutral Earthing & Body Earthing. Pls give the formula too
Re: Conductor Size
03/08/2011 12:40 AM
This has been discussed dozens if not hundreds of times on CR4; you can do a "Search all of CR4." There is more to it than some formulas, and there is no "the formula."
Re: Conductor Size
03/08/2011 12:42 AM
First you should know how much current will flow
pnaban
Re: Conductor Size
03/08/2011 1:03 AM
its a 3 Phase 750 KVA Generator
Re: Conductor Size
03/08/2011 1:08 AM
In that case, knowing the voltage might be first....
Re: Conductor Size
03/18/2011 5:41 AM
voltage will be 415, frequency 50 Hz, PF 0.8
Good Answers: 170
Re: Conductor Size
03/08/2011 9:38 AM
Assuming that it is a 415V generator, the following are the recommended earthing conductor sizes:
Neutral Earthing:
i) 1 1/2" x 1/4" (40mm x 6mm) Electrolytic Bare Copper Conductor or Strip
OR
ii) 2 x 225 sq.mm or 1 x 500 sq.mm PVC Insulated Single Core Stranded Aluminium Conductor
Body Earthing:
i) 1" x 1/8" (25mm x 3mm) Bare Copper
OR
ii) 185 sq.mm PVC Insulated Stranded Aluminium
OR
iii) 2" x 1/4" (50mm x 6mm) Galvanised Iron
Re: Conductor Size
03/18/2011 5:43 AM
how we can calculate this
Good Answers: 170
Re: Conductor Size
03/20/2011 9:59 AM
If you want to actually do the sizing very precisely, then you have to calculate the fault current at the motor terminal for a single-line-to-ground fault, duly taking into account the fault contributors and all the network impedances in line upto the point of fault. Then you calculate the conductor sizing by following the maximum permissible current density for the material chosen.
But, as there would be number of motors in an industry, it is a laborious process to undertake such an excercise. So, engineers' associations have given a ready-reckoner, assuming the nomimnal cable sizes used for the given HP/kVA. The above recommendation is from one such ready-reckoner.
Netherlands - Member - New Member Canada - Member - New Member
Re: Conductor Size
03/20/2011 3:22 PM
In many jurisdictions, the local codes will prescribe the minimum conductor size to use. These sizes are based on standard motors and/or other loads and will suffice for virtually all applications..
I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use. Galileo Galilei
Re: Conductor Size
03/08/2011 11:39 AM
British Standard 7671.
Re: Conductor Size
03/08/2011 8:56 PM
Canadian Electrical Code, table 16.
Register to Reply 11 comments
electricalexpert65 (2); jk (2); maddy1157 (3); pnaban (1); PWSlack (1); Tornado (2)
