Previous in Forum: Blind Instruments   Next in Forum: Damage LCD-DOT Matrix Display
BSDV and PSDV
03/08/2011 1:32 PM
I have seen in a P&ID the name BSDV 101, and the name PSDV 102, which refer to valves. Can someone explain the meaning?
Re: BSDV and PSDV
03/09/2011 12:05 AM
I found a PSDV = Process Shut Down Valve, but I couldn't find a BSDV.
Look also for a legend on the drawing, or some other list of abbreviations in the specs.
Re: BSDV and PSDV
03/09/2011 2:55 AM
Thanks Tornado!
There is no other reference except the ISA 5.1, which does not help.
For the BSDV, I can guess from the location and size of the valve, that it is a Blow Down Valve. In that case I think the S should be removed, leaving just BDV.
Re: BSDV and PSDV
03/11/2011 9:07 AM
  • There should be a Valve Schedule to accompany the P&ID. Both will be listed there.
  • Another place to look is the HazOp Study report.
  • Another place to look is the Process Description document.
  • Etc., etc.
Re: BSDV and PSDV
02/28/2012 5:17 PM
Boarding Shut Down Valve - see BOEM NTL No. 2009-G36 Using Alternate Compliance in Safety Systems for Subsea Production Operations
Register to Reply 4 comments
cosv001 (1); pfergus1 (1); PWSlack (1); Tornado (1)
You might be interested in: Check Valves, Gas Valves, Industrial Valves
