Previous in Forum: SHEARING STRESS   Next in Forum: Pilot Relief Valve..Simple Question!!
9 comments
Pressure Reduced
03/10/2011 2:09 PM
can any one answer me what will be the impact. if i am reducing the pressure of pumping station from 7.5 bar (designed) to 5 bar in a large irrigation network, note that the pumping station is controlled by VFD.
Pathfinder Tags: VFD controlled pumps
Re: Pressure reduced
03/10/2011 2:20 PM
I assume that you will control the pressure with the VFD, and not a throttling valve.
I can't see a problem.
03/10/2011 2:27 PM
i have changed the set point at 5 bar , but will i get the same flow at each point as it was , and will it cause to increase in velocity.
03/10/2011 2:44 PM
The new flow will be the old flow times √(5/7.5); i.e. about 81.6%
Good Answers: 53
03/10/2011 9:42 PM
Exactly! fan law will apply, GA.
03/11/2011 6:16 AM
how it come, please can you give some references
Good Answers: 53
03/11/2011 12:13 PM
flow rate ∞ pressure2
So if flow rate is doubled pressure will be quadrupled,
03/11/2011 12:39 PM
Typo--other way around--pressure ∞ (flow rate)2.
Good Answers: 53
03/11/2011 9:59 PM
Stupid mistake, Thank you for correcting,
Re: Pressure Reduced
04/05/2024 10:27 AM
The flowrate will go down. Less fluid will pass through the <...large irrigation network...> and it is possible that at its outer edged, no fluid will arrive at all.
How far down it goes depends upon the piping system characteristic curve, which is installation-specific and cannot be seen from here.
Assuming it is electrical, the current drawn by the pump(s) propelling the fluid will probably change, though in which direction is unpredictable without knowing where they are operating on their characteristic curves, which are a feature of each pump. It can be estimated by multiplying the flowrate by the pressure rise for each of the operating scenarios, which are a function of the piping system characteristic curve, which still cannot be seen from here, and comparing them.
The amount of noise generated by the installation will change. In which direction is unpredictable and an experiment will determine this.
In the limit, the only <...anyone...> who can answer the questions in any detail is the original poster.
Register to Reply 9 comments
Fezi (2); lyn (1); PWSlack (1); rakesh_semwal (3); Tornado (2)
You might be interested in: Bar Code Software, Bar Code Cards, Bar Code Scanners
