Just a question, why would you like to ignore, zero? zero is significant to minimum function. I mean given the data say, sample Min( 0.02, 0.6, 0.05, 0.0, -0.09)=-0.09
The most practical example where zero is significant- consider a gas analyzer, say for VOC
negative readings are indicated (in the real sense, there is no negative right?) but the reading is indicative that the analyzer you are using is at drift measurement and it needed re-calibration gas to make the correct reference.
Such as these device measures Min & Peak concentration of a gas.
The zero there, is ideally something that stands for the best minimum reading your device could have. Knowing the accuracy of such device say +/-1% of the Span. Then just replace zero reading with +1% if you find the minimum from all the data as zero. (BEST PRACTICAL)
This is actually an easy problem using other programming environment, in C++ this is easy you just have to input the range for you data to ignore zero, but I am not quite familiar with this in MSexcel environment. There must be some way around, doing function with range of values.
It's very interesting to find it out.
You're just insulting the intelligence of the OP. I'm pretty sure that if he didn't need to ignore 0, he wouldn't be asking how to ignore 0.
To the OP: The above solutions work easily, depending on what you are doing, you could also write a macro to delete the 0's.
Was that offensive? really. I am sorry if that's the case. I am just trying to explain a far more informative and in practical sense. It's because I think that will be helpful.
Well, I see the OP's not yet complaining. One same thing looks different at different angles by the way, just do not take your side as his/hers.
peace man!
Not offensive, insulting. I'm well aware of different looks from different angles, and for the record, I take your side, the OP is in idiot for trying to ignore 0's.
****The above is completely a joke. Laugh or ignore, I'm checking the OT box.
if some vendor not responding our request for given a quatation for related project, that time we need to consider the value of zero for relevant vendor cost in excel sheet.
that's why i need to Ignore zero from the minimum value.
JohnDG's answer is essentially correct, but misses some values.
Use the formula- =if(a2=0," ",a2) for each cell of the "modified value" column and then use the standard =min(b2..bn) formula for the resulting "modified value" column
NO MATTER HOW WELL YOU HAVE DONE SO FAR, ALWAYS TRY TO BE BETTER TOMORROW.
Design Cost
Fabrication Cost
Total
Design Cost
Fabrication Cost
Total
Design Cost
Fabrication Cost
Total
Design Cost
Fabrication Cost
Total
Minimum cost consider for bidding
5000
7500
12500
5500
8500
14000
4750
8750
13500
0
0
0what is the formula to find the minimum Cost Value from vendor costing
This is easy. The hint is replace 0 number with any alphabet. Could be n, no or any character. Min function ignores any character. You can use my first answer #1 . I'll show you tomorrow how. I am using my phone right now so i have no access to excel. Cheers
Like this? I understand. It might be that the design & fabrication could be win by different vendors.
In this case above, you will consider Vendor 3 for the Designing Works, while Vendor 1 for the fabrication works to have the minimum cost amount for the entire project.
But please confirm if this is correct.
Cheers
Design Cost
Fabrication Cost
Total
Design Cost
Fabrication Cost
Total
Design Cost
Fabrication Cost
Total
Design Cost
Fabrication Cost
Total
Please don't derived calculation in vertical position as per above, because in original my excel calculated file consist of total project equipment and packages costing (lengthy one), therefore it's not possible to provide (calculate elaborately) in vertical position
From your reply, you are working Horizontally: i.e., every vendor has a set of 3 cells, then the next vandor follows on the same row etc... your last column for the result is at the extreme right (Yes?).
Although it looks clumsy to me to have such a sheet, since it is difficult to handle if you have a big number of Vendors, I can give you a formula for 4 vendors in a row ( you can extrapolate for more if you like ):
The above is on one line and check the '(' & ')' when you extrapolate for more than the 4 vendors! You can change the last message ("None" ) for whatever suits you.
If You want to be more elegant, then you need to write a VB function that will automatically selects and work it out. Short of this, the above does the trick.
Why not use an array formula? It would be an easy solution to your problem. For example, say the range you want to check for the minimum value is C1 to C10. The formula you would enter would be "=MIN(IF(C1:C10<>0,C1:C10))" followed by SHIFT+CTRL+ENTER. The formula would become {=MIN(IF(C1:C10<>0,C1:C10))} on your screen and provide the non-zero min for the range C1:C10.
