Previous in Forum: Filler Wire for SS Pipe   Next in Forum: Ideas for Reducing Sag on 25' Tube
13 comments
Temperature Affected Materials
03/14/2011 3:09 PM
I would like to know if is a material or materials combined that shrink/push at 32F and less then return to original position at above 32F?
MB
Re: Temperature Affected Materials
03/14/2011 5:59 PM
Sorry, mate - that makes no sense.
"shrink/push"?
Try re-phrasing the question to rectify that, and you may get a sensible answer. Are you thinking about "memory" materials, or just something(s) with non-linear thermal expansion characteristics?
03/14/2011 6:19 PM
You are right, poorly phrased. Memory materials is proper
03/14/2011 6:47 PM
Sorry - can't help. But at least the others will know what the subject is.
(Welcome to CR4).
03/14/2011 6:57 PM
JohnDG isent you an answer and agreed with your commnet on "memory" materials
03/14/2011 6:58 PM
Yep - I saw it.
03/14/2011 8:57 PM
All materials shrink when cooled and expand when heated.
03/14/2011 10:18 PM
Why couldn't a simple bimetal strip do this?
(From about 39°F to 32°F, water expands as it cools/freezes. That's why ice floats.)
03/14/2011 11:23 PM
If you search on "memory metal" on google, you might find what you're looking for. Not too sure if they will meet your temperature requirments though.
03/14/2011 11:39 PM
There are also bimetal diaphragm switches that have a pronounced "snap" action. I think "Klix-On" uses this principle, and they might have some examples in your desired temperature range.
03/15/2011 3:04 AM
jip, seems like a memory metal (NiTiNol) might be what you need.
By adjusting the Ni/Ti ratio the material can be adjusted to phase shift at different temperatures.
Try "Memry metals" in the states. They were willing to ship me a sample a few years back
ditto
Good Answers: 94
03/15/2011 5:36 AM
Johnson Matthey show a couple of alloys that activate at near 0°C here.
03/15/2011 8:04 AM
There is a titanium alloy that will do this, it is called memory metal, but I couldn't tell you where to buy it, sorry!
Xanasax
Good Answers: 125
03/15/2011 2:35 PM
Depending on what you are trying to do, a rubber bladder filled with plain old H2O will perform that way.
Register to Reply 13 comments
JohnDG (3); KPG (1); lyn (1); mbell01225 (2); Nigh (1); Olebogile (1); Tornado (2); WJMFIRE (1); xanasax (1)
