Previous in Forum: How to Calculate Machining Force?   Next in Forum: Rotating Equipment
Conical Strainer for Gas
03/15/2011 9:12 AM
How to define the mesh & aperture size of a conical strainer that to be used in H2 gas compressor?
The gas does not contain any particles & strainer is to be used only for the start-up of the compressor i.e. after commissioning & regular maintainence shut downs.
Pathfinder Tags: conical strainer
Re: Conical Strainer for Gas
03/15/2011 10:30 AM
What is the size of the largest particle that the equipment can pass without damage?
The strainer mesh should be smaller than that figure.
03/16/2011 1:04 AM
The largest size of particle can be either dust particles / metallic burs / welded flux etc inside the pipe line.
But defining the size of these particles is not easy as it changes from case to case & hence i could not conclude with the size of the particle & then i posted this thread for discussion.
How do i calculate / know these sizes??
03/15/2011 10:50 AM
25microns - mesh wire 40x40
Register to Reply 3 comments
apurva vora (1); Bobby156 (1); PWSlack (1)
