Previous in Forum: Nuclear Safety and Automatic Rod Extraction   Next in Forum: Gas Flow
Synthetic Oil?
03/16/2011 12:28 AM
Hi all, I've got several motorized tools around the place with Honda engines. Log Splitter, 2000 watt generator, brush cutter, lawn mower etc. I am thinking about using synthetic oil in all the Honda engines. Our weather here averages between 30 degrees in the winter to 90 degrees in the summer. My question is this. What is a good quality synthetic oil and what would be a good weight to use? And....is this even a good idea?
Thanks, Ron
'Consider it all entertainment'
Pathfinder Tags: synthetic oil
Re: Synthetic oil?
03/16/2011 12:51 AM
FAQs - Honda Power Equipment: Honda Generators, Lawn Mowers ..
"Honda engines are developed, tested and certified with petroleum based motor oils as a lubricant. Synthetic oils may be used; however, any motor oil used in our engines must meet all oil requirements as stated in the owner's manual. In addition, recommended oil change intervals must be followed."
I wouldn't bother. But, you can, if you wish.
Good Answers: 266
Re: Synthetic Oil?
03/16/2011 1:36 PM
Most of those small engines recommend oil changes in a frequency that there would be no cost benefit. Unless of course you have access to synthetics cheaper.
Re: Synthetic Oil?
03/17/2011 7:45 AM
Even if you don't save any money on the oil, using the correct long life synthetics will reduce wear and tear dramatically in the motors as well as protecting them from sludge and other unwanted formations and make them far less likely to be damaged if they overheat......synthetic just evaporates rather than burning and leaving carbon everywhere.....a great plus point!
Also, on cold mornings, the synthetic gets to the vital parts even quicker......
The extra life of the units will more than make up for the extra costs.......and if you accidentally miss an oil change (always possible with any oil!), the negative effects will be far less.....
Any oil that Honda accepts and is marked as LongLife 3 or LL3, will be fine.....I buy mine on ebay and save a great deal of money!!!
Re: Synthetic Oil?
03/17/2011 3:59 PM
A friend of mine is a pretty savvy car enthusiast, and owns the local indoor kart race track. He switched to pure synthetics in his race kart engines quite a while ago. They get a lot of use. Much less wear, and good economics. I imagine your Honda portable power engines are pretty similar to his kart engines, but perhaps get fewer hours of use per year. I would use the same viscosity as Honda recommends.
David
Isn't the french fry the most COMMENTATOR ?
Re: Synthetic Oil?
03/17/2011 4:16 PM
Thats good info, tuned Kart engines last longer on synthetic!! I can live with that!!!
Re: Synthetic Oil?
03/17/2011 8:01 PM
Hi Andy, Thanks for the post. I've been looking for any reference to Longlife3 or LL3 marked on different brands of synthetic oil and can't find anything. Can you give me any more info regarding this? Thanks, Ron
Re: Synthetic Oil?
03/18/2011 4:16 AM
LL3 is (within my limited knowledge & experience) is always 5W30.
If its synthetic and marked 5W40, its LongLife 1 or 2. (Longlife 1 is not marked with the 1, its just LongLife). I have used them all, all were excellent.
Check out here:-
http://en.wikipedia.org/wiki/Synthetic_oil
The three (3) version is simply the latest version and can often be allowed to stay in the engine for up to 20,000 miles....even in diesels....
I have had a Mitsubishi 9 seater mini bus many years ago that achieved well over 260,000 Kms and ran just like new.......then I sold it.....
I have used synthetics since the middle/end of the 80's, running in is significantly slowed down, which is the only slightly negative effect that I have noticed.
I was given "agri" petrol once in Italy, the bus overheated for about 4 hours driving, checked timing and replaced water continually, but the synthetic stopped any damage.....a topup with Super+ eventually fixed the problems for good!!!!
Register to Reply 7 comments
4123 (1); Andy Germany (3); dhgrant (1); lyn (1); ozzb (1)
