Previous in Forum: cheap used cars   Next in Forum: DMF-Z Righy- angle Valve
DMF-Z Embedded Eletro-magnetic Pulse Valve
03/17/2011 11:02 PM
DMF-Y Embedded Eletro-magnetic Pulse Valve
Usage
Electro-magnetic valve (also called disphragm valve) is the "switch" for compressed air in the dust blowing system of the pulse bag filter.controlled by the output signals of pulse jet control device,it makes dust clean to the filter bags cell by cell to keep the resistance of the baghouse within the set range and thus guarantee the processing functions and the dust-collecting efficiency of the baghouse.
DMF-Y electro-magnetic pulse valves are embedded valves9also called submergebones0 which are directly installed on the mainifold box..They have better flow characteristics operate with reduced pressure loss,therefore, they are suitable for conditions where the pressure of the gas source is relatively low.
dust collector
Pathfinder Tags: dust collector valve
Re: DMF-Z Embedded Eletro-magnetic Pulse Valve
03/18/2011 12:41 AM
Commercial Alert!
