Previous in Forum: Hot Fuel Pipe of DG Close to 4,1 kV Cable Power   Next in Forum: Which is the Right Photo Sensor for an Application
Transformer Selection
03/18/2011 6:10 AM
please give selection guide for step up transformer for generator of 0.415 KV.if i want to step up voltage upto 33 KV which option i shsould use & why?
A. use two transformers of 0.415/11 Kv & 11/33 KV
B.use one transformer of 0.415/33KV
Pathfinder Tags: step up transformer
Engineering Fields - Power Engineering - Power Engineering Passion Engineering Fields - Electrical Engineering - Engineering Passion India - Member - New Member
Re: TRANSFORMER SELECTION
03/18/2011 6:40 AM
By both ways your purpose will get solved. But If you choose....
A - line losses will increase and component cost too i.e. you have to purchase 2 transformers.
B - Normal line losses and component cost reduced.
Sure Answers Always
Re: Transformer Selection
03/18/2011 6:06 PM
I think you should go with option B,because it will make your system more simpal and stable.For option A you may have to use Breaker b/w two transformers,which any way increase your cost only and make your system little complicated
03/20/2011 2:50 PM
This looks and sounds like a homework question.
What do YOU think the answer is (include your reasons). We will let you know if you are right.
Jack - Has actually DONE this question in real life!
Register to Reply 3 comments
electrahul (1); jack of all trades (1); Vinu_Answers (1)
