Previous in Forum: Which is the Right Photo Sensor for an Application   Next in Forum: Material for Netral Earthing Resistor
Generator Star Point Ground
03/18/2011 7:05 AM
why do we ground high voltage genrators star point if it opens in running condition then what will happen on system & machine?
Good Answers: 44
Re: Generator Star Point Ground
03/18/2011 6:04 PM
Then you have no safety ground. Neutral rides on ground at the generator set. Don't touch it!
Good Answers: 170
03/20/2011 9:42 PM
Be ready to loose the generator - during a single line to ground fault elsewhere in the system.
03/27/2011 11:31 AM
In the event of one or two of the phase circuit protective devices operating, then there will be potentially lethal voltage appearing on the neutral downstream of the neutral point link. This may prove fatal to the electrician trying to locate the fault on a live system.
Register to Reply 3 comments
cuba_pete (1); electricalexpert65 (1); PWSlack (1)
